Don't take any notice of what they look like in the pics. The parts often don't look anything like them.
If you enter your VIN, then the only parts listed should be the correct ones for your car.
Note that changing the brown one might just change the position of the temperature gauge needle, but will have no effect whatsoever on the running of the engine.
Wonder if one of the other sensors is the switch for the check panel overheat light?
15 is the one that looks like a switch - but then, you can't go by the pictures.
You can set the ETK to show all parts, IIRC, so this should identify it.
Neil ... doubt it will do anything to resolve "heat issues".
The brown will give a slightly different reading on the dash and the blue may make it idle better.
Brianmoooore wrote:Can't help you. Since my hard drive failure a few months ago, and my subsequent re install using Windows XP pro, I can't install the ETK!!
Lousy luck. Time to get a Toshiba Libretto & keep the ETK in your pocket!
