M20 2.0i low running temp?
J_Mac
Hi i have a 2.0i m20 e30 and the running temp is only at a quarter, my first car was a e30 1.8i and then a e34 2.5i both run a temp at half way.
So is there something wrong, is it just the "blue relay" i've read about on here, engine thinking it's cold all the time and over fueling ect, because also i get pi55 poor mpg 16-17 everyday use.
After xmas i'm going for a m50 2.5/2.8 conversion so hoping this is just a easy fix and a non expensive one just to get me through the winter
Any help is much appreciated
jmc330i
Quarter is about right. My 2.5 runs at the quarter mark all the time and moves up to half in traffic.
Anything from quarter to half is fine when driving along - the 'middle' of the temp guage is only a small temp range. Start worrying if it doesnt get to the 1/4 mark or runs over the 3/4 mark.
The blue temp sensor youve read about is for the ECU, the brown temp sensor is for the temp guage.
James
'91 325i Sport
'93 318i touring 16v
'91 325i Sport
gcorky
- Boost Junkie
J_Mac
it's never reached the mid mark, even when i changed the sump and left it running in the garden for half hour didn't budge from the quarter mark, so everything is ok apart from the mpg
surj
i agree with boost junky themo stat wants replacing engine is runing to cold hence your mpg running your engine cold would probaly cause engine wear aswel bms always run halfway bank on they do creep up to 3 quaters in traffic
jmc330i
Not always - a quick quote from a Zone expert....surj wrote:bms always run halfway
Anywhere between the two coloured zones is normal operating temperature. The whole centre section of the gauge only covers a few degrees, and anywhere there is fine.
Most E30s run between just above the quarter mark and the half way mark.
My 325i never ran over the 1/2 mark (always at 1/4 upto 1/2 in traffic) in the 3 years I drove it. The 318i I bought 8 months ago ran halfway between 1/4 and 1/2 - the 318i now has my 2.5 engine fitted from my Sport and runs at 1/4. It does creep over 1/2 in traffic now, but I know the fan coulping is pretty knackered.
If the car in question runs at 1/4 on the move and upto 1/2 when left to idle or in traffic, then thats fine. Never moving above the 1/4 mark does indicate a thermostat problem, but I didnt read the post in that way. How well does the heater work?
James
'91 325i Sport
'91 325i Sport
Richy325iTouring
same as the last 3 of mine james
they have been running on just over quarter way unless im idling then its just under half way
anything above or bellow i would start worrying
gcorky
- Boost Junkie
if your engine doesnt reach halfway ever ,theres a fault .
car should sit all day idling with temp around halfway.....if your gauge is correct and sitting at a quarter the engine is overcooled,and your stat aint doing its job as intended.
at the same time normal operating temp should be reached a few minutes after driving off.
all this is assuming your car is as factory...correct brown sensor,tip top rad,viscous,stat etc.
Don't agree! It depends on what thermostat is fitted for a start.gcorky wrote:if your engine doesnt reach halfway ever ,theres a fault .
Driver's Handbook says anywhere between the two coloured zones is normal operating temperature. This should really read "anywhere well clear of the coloured zones" and, in UK ambient temperatures, is anywhere between the quarter mark and just over half.
My two taxed and tested E30s in daily use have one gauge that sits at exactly half way, and one that sits just over the quarter mark. Both rock steady, and on their marks within 1.5 miles from cold.
jmc330i
Must admit, I missed that postJ_Mac wrote:it's never reached the mid mark, even when i changed the sump and left it running in the garden for half hour didn't budge from the quarter mark
What I said. Around 1/2 when left idling, 1/4 on the move with airflow etcgcorky wrote:if your engine doesnt reach halfway ever ,theres a fault .
James
'91 325i Sport
'91 325i Sport
gcorky
- Boost Junkie
are you telling me that a couple of degrees will give quarter gauge variation??bearing in mind stock etk stat is 80 degrees and the red zone is overheating?im surprised if its the case...but there ya go...Brianmoooore wrote:Don't agree! It depends on what thermostat is fitted for a start.gcorky wrote:if your engine doesnt reach halfway ever ,theres a fault .
If the temperature increases at idle, then the fan and radiator aren't doing their job completely. If it drops when running then the thermostat isn't doing its job fully.
As long as it doesn't move about too much, then both are totally unimportant and irrelevant!
gcorky
- Boost Junkie
Brianmoooore wrote:If the temperature increases at idle, then the fan and radiator aren't doing their job completely. If it drops when running then the thermostat isn't doing its job fully.
stat forces idle temp to increase-(from cold-stationary) nothing to do with fan/rad till certain conditions are met-although i agree with your second sentence...
The stat is part open at normal running temp with the engine not under load. If the engine is then idled, and the temp starts to rise, the stat should open more to allow more flow through the rad to be cooled by the fan.
If the temp rises despite the stat opening, then the fan/rad are not doing their job properly.
surj
ive had 323i,316 x 2 325 x 2 520i x 2 525i 525e and a 728i they all once at operating temp bang on half way should take a few of mins to get two half way in my opinun anything sitting on a quater of the way theres something wrong somewhere
J_Mac
Yes heater's top notch and it's reached it's quarter mark within a couple of miles. Never change's after that, i drive it to manchester and back in a weekend from kent, without a problem. It does creep about a millimetre over the quarter but only when the engines just turned off after a run, but thats normal i always thought.
Everything is standard as far as i can see, so i'll get a new stat, i've done 1 before on a e34 there not a problem and only a few pennys
Also these are on ebay .. i know ebay but ..
"Auction is for a lower temperature (75 degrees C) Thermostat. Its OEM Whahler part# RGM 1153172100275. This thermostat will reduce operation temperature by about 13 degrees C. The lower operation temperature will also lower underhood temperatures and resulting in longer live parts such as; seals, gaskets, hoses etc. Many performance tuners use these to lower temperatures on their modified machines and get a pretty penny for them. Note gaskets (or o-rings) not included."
So i'm guessing a safer engine?? but in return of poor mpg??
Typical ebay bollox!!!J_Mac wrote: "Auction is for a lower temperature (75 degrees C) Thermostat. Its OEM Whahler part# RGM 1153172100275. This thermostat will reduce operation temperature by about 13 degrees C. The lower operation temperature will also lower underhood temperatures and resulting in longer live parts such as; seals, gaskets, hoses etc. Many performance tuners use these to lower temperatures on their modified machines and get a pretty penny for them. Note gaskets (or o-rings) not included."
BMW could design their engines to run at any temperature they choose, but after millions of marks of research decided on whatever temperature their chosen thermostat is.
Cooler is not better, hotter is not better. Exactly what BMW intended is spot on!
Well, your "opiniun" is at odds with what BMW state in the driver's handbook!surj wrote: in my opinun anything sitting on a quater of the way theres something wrong somewhere
Martinaston
Check the fan spins with a bit of resistance when the engine's cold, if its seized it will over cool.
The guage is just a guide so i wouldn't worry about where it sits just as long as it moves.
As for the crap MPG, have you serviced the thing ?
There is NO nucleus.
surj
when i qoute theres somthing wrong i mean in cooling not the engine is fudged ive run the m20s before with no thermostat in and the temps been the same 1/4 is the farest the needle gos unless you are in traffic but i find the m20 runs best how is should run at halfway and asfar as i know how bmw intended it to run. ive got loads of bm friends and all there cars run at halfway if the car runs at a quater of the waythe heater will be crap in that case put the heater on full on very hot setting and the temp will probaly go lower then u get even colder air ehh bmw build everthing quality and decent ie not a coldish heater replace that thermostat sun then put the heater ohh feel that heat its cookin me toes
J_Mac
Thanks for the input, will probably be doing the weekend. Thanks again
abelai
I have a 325i sport and the temperature sits at just over 1/4 sometimes goes to halfway and a little bit over! I have a friend who was a bmw technition for 10 years 85 to 95 and he said the gauge should always show half way and that the viscus fan and thermostat should constantly adjust to keep it there which makes perfect sense to me as this is how all modern cars work to keep the engine at the optimum running temperature.
I have replaced the termostat (genuine bmw ouch) water pump and the radiator (for the aircon version) temp sender for gauge and gauge all with no improvement.
Have done a compression check and all read 12 except no. 2 cylinder which shows 5. So now I know the headgasket is dead and blowing air/steam into the cooling system past the thermostat forcing it to stay open and the rad is then cooling it more. The m20 cooling system actually allows the air to escape instead of blowing the water out so thats why I have no lose of coolent which was the confussing part. I noticed the slightly sooty coolant colour because I had changed it about 8 times in 6 months so it should have been clean.
Will change headgasket and hopefully all will be good.
If I can't fix it I'll f**k it up so bad nobody can!!
