Hi guys
I have a 1990 320iA, with 156000 miles on the clock.
The engine responds well and has no major glitches apart from a low idle, around 680-700 and there is a slight "stumble" which is almost like a very slight miss.
I just completed an Inspection I and additonally replaced the d. cap & rotor as there was wear and towers 4 & 6 had slight cracks.
The response otherwise is very smooth and whilst the plugs are slightly light the mixture seems fine.
Any suggestions?
low idle
