Rev counter
dn808e2
Hi . my car has been standing for some time .And when i started it REV counter stoped working ,but other instuments are OK. oil pressure ,speedo,fuel ,working fine
Any ideas ?
Any ideas ?
Could be one of the many effects of failing SI board batteries. Also try unpluging and reconnecting the C101 engine loom plug and socket a couple of times.
Does everything else electrical work on the car?
smithy318i
mine stopped working because a fuse had blown. cant remember which one though.
dn808e2
yea, evrything is working but not Rev .
c101 wire plug,is it uder steering column?
where does it go in the engine ?
C101 is the big round plug and socket on the bulkhead in the engine compartment, just inboard of the fusebox.
Fuses 10, 12 and 21 are all feeds to the instrument cluster, but all feed other things as well. (Hence the "does everything else work" question.
dn808e2
I had look in fusebox , all are ok.
then i took apart dashboard and cheked connection with voltmeter and that's what i saw
i don't realy knew what i was doing but as far as i understand one of the connections isn't good
so it doesn't show it on the screen of voltmeter, next two are ok . the rev counter itself cost around 150 at the shop, so just wanted to b sure before i have to buy one.
if i'm doing rubish just let me know
here they are
why on the 3rd pic no signal ?
pic 1
pic 2
pic 3
here they are
pic 1
pic 2
pic 3
Don't recognise that connector at all! Not another pre facelift, is it?
dn808e2
thats how the back of cluster box does look like
don't know where them 3 wires go ECU or elsewhere?
What model and age of E30 is this?
dn808e2
M3 E30 same as on the picture 1990 158kw , that's my baby but after staying in the garage for some time
just stoped working .
delboye30
Mate exactly the same thing happened to my sport the rev counter stopped working. Anyone know What fuse it could be?
The rev counter and its wiring in a non M3 E30 bears no resemblance at all to this one.delboye30 wrote:Mate exactly the same thing happened to my sport the rev counter stopped working. Anyone know What fuse it could be?
dn808e2
So can anybody tell me what should i do ?
rev counter cost around 130 +vat, didn't realy wanted to buy it before i know that i need it.
timmyboy
dn808e2
thanks Timmiboy
BIGJO
Isn't it some kind of sensor? My speedometer's on & off and was under the impression from this mechanic that it was an electrical fault. Therefore, to get an electrician to have a butchers............
Regards, BJ.
Regards, BJ.
