but pis**d off anyway.
mot & lowered cars.
gooner1
- Out humping Reindeer
Just come back from an mot test which had to be aborted after 30mins as the car was so low they couldnt get it on the ramps.Have had to rebook with a garage that has sunken ramps.Not their fault i know
ajm-e30
i had the same problem mate, i got a 60/60 drop on mine
zaust
- Zone day release
NIX
I remember when I had a 60mm drop all round on mine along with a large chavtastic back box. When it came to having it put on the back of a recovery truck one time, it was so painful to watch the back end scraping along the ground!
jmc330i
Have they not heard of blocks of wood???gooner1 wrote:Just come back from an mot test which had to be aborted after 30mins as the car was so low they couldnt get it on the ramps.Have had to rebook with a garage that has sunken ramps.Not their fault i know
Both my E30s cant get on a set of ramps without blocks of wood and Ive never had a problem with MOTs.
Last month was MOT time for the touring, and I couldnt even get into the yard without blocks of wood because of the speed bump in the gateway. Still had no problems with the MOT.
James
'91 325i Sport
'93 318i touring 16v
'91 325i Sport
dimebag_from_hell
over here in northern ireland, everyone i know changes springs for mot, simply you wont pass if its lowered
garyp_E30_325i
Never heard of that problem, but in my estate if I don't take it easy going over the bl**dy huge speed ramps my exhaust scrapes... will the council pay £900 for a new SS system if mine gets f*cked on their bl**dy speed ramps... NO, t'b*stards!!!!
and I've only dropped her 40mm.
Anyway, regarding MOT's and lowering, your car can fail an MOT test if it is lowered using only springs. If the tester believes the springs can jump off their seat (because the shock extends further than the height of the spring) then they can legitimately fail the car. If that's the case better to use metal ties to tie the spring and shock together so it can't move too much. If the car is lowered with a kit (springs matched to shocks) then it's no problem.
I know that wasn't the issue, but it's the same subject...
'89 325i - was an SE but not anymore, was bronze-beige metallic (yeuch!) but now techno-violet (thankfully)
'89 Toyota Corolla GTi-16 - track, hillclimb & sprint car (yeeha!)
'08 Buell XB12Ss - American engineering at it's 'best'... good fun though
gooner1
Not sure how much mine is dropped but i never have a prob with speed bumps but having
said that if i need to get the trolley jack underneath i have to use a scissor jack to raise it first.Was only the steering and suspension left to do on the mot.Flew through the emissions.
slik
never had trouble with the old e30 getin onto MOT ramp (60/60) but remeber having to find wood to get over a bitchy speed hump due to ma exhaust on a one-way street (got it changed after that). the traficc loved me
gooner1
Flew through mot today.
One advisory note - no seats fitted in rear.Did they think i had,nt noticed ?.
Puzzled as to why seat belt checks are marked with not applicable
Geeman
My track car failed one as I had to raise the front coil-overs to get it on the ramps.. then the headlights were aiming too high... wankers!
ian332isport
My car gets on the MOT ramps fine (ramp sunk in the floor), but they have big trouble getting the MOT jack past my sump guard and exhaust. It usually takes a couple of blokes underneath to push the car upwards to get the ramp past. Luckily I'm on good terms with the garage and don't get any grief. They could officially fail (or refuse to test) it if they wanted.
Ian.
Ian.
Dan320is
My touring had its MOT last week, the garage I used didn't put my car on a ramp. They just put it over a pit which had channels along the side for one of those jacks that lifts from underneath and not the side. ?????? Should it have gone on to a ramp???????????
jmc330i
The garage I used to work at did the MOTs over a pit - AFAIK it doesnt have to be a ramp.
James
'91 325i Sport
'91 325i Sport
juschilin
I once had a problem where they couldnt get the car onto the brake testing machine because the car was lowered 60/60mm with reiger body kit, so raised the car to 40/40mm.
slik
its mre fun wen u kno an mot tester who givve u MOT without lukin at the car
ian332isport
Any chance of that in Englishslik wrote:its mre fun wen u kno an mot tester who givve u MOT without lukin at the car
Jon_Bmw
- Dangerous when thinking
Something about enjoying trying to use the brakes only to find out they no longer workslik wrote:its mre fun wen u kno an mot tester who givve u MOT without lukin at the car
gooner1
Got to agree with Jon on that, know mot can be a pain but would rather know there is a problem beforehand.Besides its about the only time i get to see underneath my car properley.Jon_Bmw wrote:Something about enjoying trying to use the brakes only to find out they no longer workslik wrote:its mre fun wen u kno an mot tester who givve u MOT without lukin at the car
