325i TB and manifold on a 320
Brian28
Post Fri Dec 01, 2006 11:22 am
Is this a straight bolt on power mod without any other tuning or tweaks? Not going to do it myself (if JimmyC is looking in and thinking of the race car :D :wink: ), but am breaking a 325i and don't want to advertise it as a 320i bolt on power mod if it won't work.
Brian
For sale - E30 320i racer project - sold.
Ant
Retired Team Member
Retired Team Member
Post Fri Dec 01, 2006 11:52 am
the TB can be used with a chip swop to up the fuelling.
the inlet would bolt up but its a bad idea, the bigger bore runners will slow the airflow down and reduce torque dude
HTH
Andyboy
Alpina Colada
Post Fri Dec 01, 2006 1:46 pm
The trouble is there isn't enough metal in the 320i manifold to make a 100% job of the 325i TB. It's also incredibly hard work to open up the 320i manifold as there is so much metal to remove. On the other hand it takes about 20-30 mins with a rotary stone to open up the top corners on the 320i head ports using a 325i inlet gasket as a template. I think the 325i has very slightly longer runners than the 320i manifold anyway. You might well lose a bit of low end torque as the Antmeister says but you'd gain so much top end. I wish I'd done mine this way now.
Brian28
Post Fri Dec 01, 2006 5:06 pm
Okey doke, thanks guys. I'll just advertise it and whoever can do what they like. Just didn't want to say it was a simple bolt on and mislead people. Alas for racing we're not allowed to touch the head other than basic decoke and clean up, trying to create a level playing field. But looking at some of the power figures, I reckon some people may be being a bit vigerous when cleaning off the port soot deposits with a dremmel :eek:
