Steering making funny noises and getting a little bit stiff?
NIX
Post Thu Nov 30, 2006 9:53 pm
Right my steerings not been 100% for a while now, but recently when turning at low speeds or from when parked I sometime hear this weird noise. The only way I could describe it is something similar to pulling a heavy wooden table across a wooden floor if you get what I mean but slightly lower pitched, or on a slightly more strange way of describing it, like the sound wales make :roll: :?
Don't know if the noise desciptions really help anyone, but the other sympton is the steering itself gets a little stiff at the same time as the noise.
Any ideas??
Thanks,
Nick
dips346
London Meets Main Man
Post Thu Nov 30, 2006 9:55 pm
power steering pump maybe
anton
Post Thu Nov 30, 2006 9:56 pm
hi there.
i also get that noise, never while driving, but while parking. the noise is just like u described
i have november 1989 325i 4door e30.
any ideas any one?
regards
Anton
NIX
Post Thu Nov 30, 2006 9:59 pm
Glad it made sence to someone then :D
Mines also an '89 325i but 2dr.
Post Thu Nov 30, 2006 10:42 pm
Your steering fluid a nice red colour or murky grey?
NIX
Post Thu Nov 30, 2006 10:44 pm
I'll have to check. What colour should it be, I'm guessing the nice red option?
Whats the deal if its the murky grey? Dodgy power steering pump like Dips reckons it could be?
Post Thu Nov 30, 2006 11:01 pm
Flush and change it is the first thing to try. Pump may have survived.
NIX
Post Thu Nov 30, 2006 11:18 pm
Ok mate, I'll check the colour tomorrow. Thanks for the info as always!
Anton, let us know how you get on with yours too.
J_Mac
Post Thu Nov 30, 2006 11:32 pm
yes should be a nice red oil, ATF fluid, do you even know if there's any in the tank at all, mines lowered and speed bumps have worn the pump at the bottom and leaks very very slowly, so i have to top it up every once and while, so if your's has been leaking like mine it wouldn't be noticable
NIX
Post Thu Nov 30, 2006 11:34 pm
Hmmm good point. My car did have a 60mm drop for about a year and it did you used to scrape like a bitch!
Like I said, I'll take a look tomorrow. Thanks for the heads up!
reddevil
Post Fri Dec 01, 2006 12:22 am
I too reckon it's the fluid because mine does exactly as you describe it. Don't forget that there's a nice article to be found in the articles (amazingly enough) section, describes exactly how to go about doing a change.
Red Devil
1991 (H) 318iS Diamond Black, M-tech II spoiler.
K&N Panel filter-Viper2 chip-Zone BBTB
XBOX LIVE - reddevil1976
Chris-W
Post Fri Dec 01, 2006 11:01 am
I'd be astonished if a lowered car managed to wear the PAS pump away!
NIX
Post Fri Dec 01, 2006 11:22 am
reddevil wrote:I too reckon it's the fluid because mine does exactly as you describe it. Don't forget that there's a nice article to be found in the articles (amazingly enough) section, describes exactly how to go about doing a change.
Red Devil
Nice one mate. I dont visit the articles section enough. Loads of useful stuff on there!
E30GAV
Post Fri Dec 01, 2006 11:56 am
haha nick ive got the same problem then . . . i dint think much of it but ges i better chek mine out 2!!!
gav
NIX
Post Fri Dec 01, 2006 1:28 pm
Yep, checked the ATF resevoir and it is low along with being pretty murky. Gonna top up in the mean time but then flush and renew over the wkend hopefully.
Reckon the 'V' belt needs replacing too?
Thanks,
Nick
