Whats the best way of getting the little buggers out, do they just pull or prise out, they don't seem to want to budge and i am scared of breaking them
M20 injector removal
oguz327
- Captain Armco
I need to strip down my inlet manifold and the only thing i cant seem to remove are the injectors.
DRIFTBOY
They do stick in there!
I'd try plenty of WD40 to hopefully make the seals a bit slippy.
It sometimes help to rotate and rock the injectors side to side as you pull, I doubt you'll break anything.
They usually come out with a big He-Man / Incredible Hulk type pull.
Just be careful where and how you do it as you might punch yourself / the missus / a wall etc. when they do release!
Best to use new seals when re-fitting, only a few quid from a dealer.
And I believe it's the same seal for the fuel pressure regulator.
dobbie82
- Location: Dolgellau, Wales (NOT A TRADER,broken a car,got lots of bits)
have you pulled the little clip off each one?
hubby accidently punched my hand!Just be careful where and how you do it as you might punch yourself / the missus / a wall etc. when they do release!
e30 related ebay auctions + shop(MY Stuff for Sale), http://tinyurl.com/64aufr
My Feedback on the e30zone: http://tinyurl.com/dobbie82feedback
DRIFTBOY
Have you have got the inlet manifold off and the fuel rail off the manifold! ??oguz3001 wrote:I need to strip down my inlet manifold and the only thing i cant seem to remove are the injectors.
oguz327
- Captain Armco
Inlet, clips and fuel rail are off, just the injectors left.DRIFTBOY wrote:Have you have got the inlet manifold off and the fuel rail off the manifold! ??oguz3001 wrote:I need to strip down my inlet manifold and the only thing i cant seem to remove are the injectors.
Will get some WD on there and leave to soak overnight,
many thanks
oguz327
- Captain Armco
Cheers for the help everyone, removed them this evening, they were still hard work but managed to prise them out with a screw driver as they wouldnt pull off. Hopefully i havnt damaged them.
One more question, whats the best way of giving the injectors a good clean, can i soak them in diesel?
topspark
to clean them properly you need to get them in an ultrasonic bath and apply 12 volts to energise them.
Think templ8 did his like this with good results.
lee
lee
1989 SCHWARZ 320i SE , 4 DOOR!!!!
You say the magic's gone,Well i'm not a magician
You say the spark's gone
Well get an electrician..........
