Off to buy a M3 very soon...help !
M3Tony
I'm off to see M3 on Monday - and appreciate any thoughts from you !
Any pointers appreciated. My 3rd E30, so I can see the obvious by now, but I don't know what to look for or ask, specific to M3. How do I check what BHP, etc...she was when new ?
Thanks, Tony
Thanks, Tony
Rich_W
Age mainly dictates the engine spec. 1990 on are 215bhp everything else is 195bhp.
Save for the Cecottos/Ravaglias/Evo2 which are 220bhp.
Have a look on www.s14.net if you haven't already. IIRC theres a buying guide on there somewhere.
Or Try.
http://www.totalbmwmag.com/Buying/BuyingFeb02.pdf
Better than nowt I guess.
Or Try.
gary
CAT 2.3ltr = 195bhp
Non CAT 2.3ltr = 200bhp
Later 2.3ltr = 215bhp (G,H plate)
EVOII, Cecotto, Ragvilia = 220bhp
EVOIII 2.5 ltr = 238bhp
Service history is a must. Shut lines on panels as a lot will have been involved in accidents. Rust on the bottom of the rear arches and around the sunroof if it has one.
The scuttle panels are weak pionts and a fecker to to put right. The usual for any car... gearbox noise as well as the diff. Blue smoke on start up or when opening it up.
Ask the owner if he drives it hard when the oil temp is under 75oC , if he does then be wary, they need to be warm when gunned.
If it is noisey on start up it will most likely be a knackerd timming chain tensioner, these can be replaced with an E36/E46 M3 or the original E30 for about 30 quid.
Buy the best you can, go on condition rather than miles on the clock as a poor one will be an absolute money pit.
I have owned these cars for the past 9 years and love them.
I have probably forgot a shit load, but there are more knowledgable people than me on here so I've no doubt they will be on here in time
evostormm
Have a look here. Cecottos and Ravaglias in fact had the 215bhp engine, not exactly the same as that of the EvoII (220 bhp);
http://www.bmwmregistry.com/model_faq.php?id=8
The following is quoted from the BMW M Registry site which is very informative and amongst the most accurate sites.
How many versions of the S14 engine are there and how are they different?
BMW Motorpsort built five road-going versions of the S14 powerplant. The “standardâ€a S14 engine has a bore of 93.4mm and a stroke of 84mm for a total capacity of 2,302cc. Without pollution controls, it is rated at 200 hp (DIN) at 6,750rpm and 176 lb/ft of torque at 4,750 rpm. A version of this engine equipped with twin in-line catalytic converters produces 195 hp (DIN) or 192 hp (SAE) and 170 lb/ft of torque at the same engine speeds. This was the only variation of the S14 sold in North America.
A second catalyst-equipped version of the S14 was introduced on the E30 M3 Cecotto/Ravaglia special editions in April, 1989. This engine produces 215 hp (DIN) at 6,750 rpm and 170 lb/ft of torque at 4,600 rpm. The increased power is largely due to a reprogramming of the Bosch Digital Motor Electronics (DME). This engine also became the standard European-spec E30 M3 engine as of September, 1989 production.
The most powerful evolution of the 2.3-liter S14 was introduced in the M3 Evolution II starting in March, 1988. Changes included new pistons that raised the compression to 11:1 (from 10.5:1), a more effecient air intake, lightened flywheel and reprogrammed engine management. This non-catalyst powerplant is rated at 220 hp (DIN) at 6,750 rpm and 181 lb/ft of torque at 4,750 rpm. These engines have white cam covers with the tri-color Motorpsort logo painted on them.
The final version of the S14 features increased cylinder bore (to 95mm) and a long-stroke crank for a new total displacement of 2,467cc. This engine was used exclusively in the 1990 E30 M3 Sport Evoltuion, built from 12/89 to 03/90. In addition to the increased displacement, the valves were enlarged and a more aggressive cam was fitted. Special nozzles sprayed oil under the pistons to keep them cool. All Sport Evolution motors were equipped with catalysts. Power increased to 238 hp (DIN) at 7,000 rpm, though peak torque decreased slightly (over the Evolution II) to 177 lb/ft at 4,750 rpm. These engines use the regular black cam cover but have red spark plug wires.
maxfield
theres a macau cecotto in the for sale section for 9k which looks quite nice
in macau blue too
if its possible get some one who knows what there on about go with you
in macau blue too
playo
Is that the one from cardiff?maxfield wrote:theres a macau cecotto in the for sale section for 9k which looks quite nice
in macau blue too
Not far from me&simon, I'm sure he as i, wont mind having a look for you.
Ant
- Retired Team Member
Great info, must admit though, I'd not ask the seller, I'd see what they behaved like on the test drive ( them driving obv ) when doing demo drives for clients in the turbo SE , I always drive around in slow motion til the oil temp hits the sweet spot, this time of year thats 17 minutes or soAsk the owner if he drives it hard when the oil temp is under 75oC , if he does then be wary, they need to be warm when gunned.
caned from cold - walk away or knock them the cost of a rebuild, the S14 is strong, but nothing can take abuse 4 ever.
good luck with the viewing dude
Email FTW
eamo
Things to look at for are:-
front subframes tend to crack from heavy track use. also check for dimples in the roof around ariel - again a sign of heavy track use. stress points are the areas around the bottom of the windscreen. If there are any cracks its a sign of crash damage and/or heavy track use.
rust wise check all arches, around the lights in the boot, also around the number plate on the rear, have a good poke under the fuse box. Also prise off the plastic covers where the wipers are, shine a torch in there and check for holes/rust - very common to have rust here.
mechanically - check the usual stuff suspension wise, front wheels should sit towards the front of the car instead of in the middle of the arch, engine is ok to be a little rattly on start up and oil light should go out striaght away. gearbox may be slighlty nothcy in 1st and 2nd when cold. if its notchy when warm you have worn syncros. When you have the car warmed up drop it from 4th into 3rd at high rpms and then into 2nd at high rpms - if it crunches you have worn synros (good test this one)
Electic fan should kick in at 3/4 way and cut off after 30sec. Keep an eye on this. There should be no smoke or rattles from the engine. When driving it drive it up through the gears - it should pull like a train to the red line in all gears. Let the owner drive it first from cold and see how he drives it. If he looks after the car he will let the oil warm up before giving it the holly. It should also tick over at around 750rpm. IF it fluctuates from 600rpm to 1200rpm its the rubber blocks around the inlet manifold. not an expensive job to repair.
If the car has been resprayed for any reason you will notice the side skirts will have the same satin finish as the car. WHen these cars left the factory the side skirts had a dull matt finish.
thats all i can think of at the moment - if theres anything in particular you need advice on give me a shout.
happy hunting!!!
happy hunting!!!
M3Tony
Great stuff guys - I feel more confident, and will try to keep my cool !
I have rec'd loads of scanned documents, service history etc...if anyone has www that could accept a few megs, and wouldn't mind casting a more experiences eye over them ?
Cheers.
Cheers.
andrewe30m3
if they are jpeg - sign up an account with photobucket.com and then host them on here. Its free and takes about 5 mins.
good luck.
good luck.
Rich_W
erm,eamo wrote:There should be no smoke or rattles from the engine. When driving it drive it up through the gears - it should pull like a train to the red line in all gears. Let the owner drive it first from cold and see how he drives it. If he looks after the car he will let the oil warm up before giving it the holly. It should also tick over at around 750rpm. IF it fluctuates from 600rpm to 1200rpm its the rubber blocks around the inlet manifold. not an expensive job to repair.
i) Rattles from engine are par for the course on the S14. Not hydraulic followers.
ii) 750RPM is too low for the idle speed. And tbh my inlet blocks needed doing but I noticed no real idle hunting. Obviously a difference when Id done them, but unless they are really really nackered you wont get hunting IMO. Blocks BTW are £50 each (need 2) and you'll need to take the throttle bodies off to do them.
dimebag_from_hell
good luck tony, hopfully you get one in as good a nick as the 325i sport you sold me. it is a pleasure to drive btw and sound absolutley amazing! my dad is buying an aston martin db7 and he even admits my 325i sport sounds nicer than it!
good luck tony, post pics if you can!
M3Tony
Just need to burn some CDs for the ride home
) Wife will be running home in Merc diesel estate, so she can be my "wing man" round M25 ... hee, hee
Douzeper
So you reckon this one has been sprayed??eamo wrote: If the car has been resprayed for any reason you will notice the side skirts will have the same satin finish as the car. WHen these cars left the factory the side skirts had a dull matt finish.
http://cgi.ebay.co.uk/ws/eBayISAPI.dll? ... 0051477005
http://www.ni-bmw.co.uk
Northern Ireland BMW
eamo
I had to replace the inlet blocks on the evo 2 and the symtom was the idle hunting
Rich_W
Well the valve gear is very noisy. And of course the chain tensioner gets noisy when old which results in a sound not dis-similar to a rattle. (e36 upgrade)
And evidently your blocks were in a worse state than mine. As I only got minor hesitation not hunting.
eamo
if you re-read my post, i have said that there can be a slight rattle on startup but thats all. this is due to as you have pointed out - the chain tensioner. other than that the engine shouldnt rattle.
cheers
cheers
eamo
only evo 2s were 220bhpRich_W wrote:Age mainly dictates the engine spec. 1990 on are 215bhp everything else is 195bhp.
Or Try.
cecotto and ravaglia were 215bhp
eamo
heres a lis of chasis nos and corresponding models
http://www.bavarian-board.co.uk/uploads/Eamo/m3vin.txt
