koni or h&R ?
TW166Y
Sun Nov 26, 2006 8:52 pm
thinking about going for either one of these kits, 325 setup for my m30 conversion.
I want to know what you fella's think regarding these kits, if youve had them fitted to you car etc.. and can you tell me the best between the two. Please dont comment if your only going by "the name" these two brands are as good as eachother, so im told. with the konis you have the extra advantage of top adjusting, for hard / soft ride. but with the h&r kit shocks are just matched so im led to believe. (i may be wrong). I really only want to lower the car 40mm as i feel the weight of the m30 will be more than enough to push it down an extra 10mm at the front winkeye (i hope)! I might drop it 60mm all around though and make the arches fit if you get me... :mad: 9j rims are gonna catch like a bitch either way. :cry:
Right... what should i spend £400 on.... KONI kit or H&r Cupkit?
thanks everyone :wink:
Saying goodbye to 4-pot wrongness
Templ8e30
Mon Nov 27, 2006 10:16 am
Hi buddy, I have the adjustable kni's on my 327i.
I really like the adjustability, you'd be able to compensate for the heavier M30 with these as well.
They can be set from reasonably firm to absolutely rock solid (where it feels like the tyre side-walls are doing the shock absorbing).
The only negative I have with them is that the rears aren't top adjustable, you have to remove the bottom mounting bolt then pull down a rubber and a plastic washer then fully compress the shock and turn it to adjust 8O .
Otherwise it's a brilliant setup.
They're £320 ish in the zone shop BTW.
Cheers,
Iain T
2007 Mazda 6 2.0 estate
TW166Y
Mon Nov 27, 2006 4:29 pm
thanks iain mate!
is that a picture of the kit fitted below your post? if so how low is it because it doesnt seem as low as i want to be.. :(
Karan
Mon Nov 27, 2006 5:13 pm
h and r is better having tried both
dazleeds
old skool raver
old skool raver
Mon Nov 27, 2006 5:18 pm
TW166Y wrote:thanks iain mate!
pretty sure thats an old pic of Iains car twiggs
but also his isnt very low compared to most but i think he is running mtech springs may be wrong
im also having exactly the same thorts mate
h&r,s or koni,s or inverted billies just cant decide
gonna get Iain to take me out for a drive asap so i can get a feel for the koni,s winkeye
www.oldskoolfantasy.co.uk
TW166Y
Mon Nov 27, 2006 7:59 pm
thanks for the input guys... i just need some pictures of the kits fitted now a.s.a.p :cry: i need the kit pretty sharpish too 8O
stuartgallafant
Mon Nov 27, 2006 8:01 pm
O/T here pete, but M30? what happened to the M50?
fuzzy
He who sleeps with "Gingers"
Mon Nov 27, 2006 8:15 pm
are you not concidering bilsteins? ive used the spax adjustables and found them to hard even on the softest setting,bilsteins are what ill be sticking with from now on.firm but comfortable ride.theres picks of mine on a 60/40 drop on my thread in the photo gallery.
TW166Y
Mon Nov 27, 2006 8:43 pm
stuartgallafant wrote:O/T here pete, but M30? what happened to the M50?
mate that went out the window ages ago... im not far off banging the lump in now winkeye
TW166Y
fuzzy wrote:are you not concidering bilsteins? ive used the spax adjustables and found them to hard even on the softest setting,bilsteins are what ill be sticking with from now on.firm but comfortable ride.theres picks of mine on a 60/40 drop on my thread in the photo gallery.
cheers fuzz. :wink:
stuartgallafant
Mon Nov 27, 2006 9:17 pm
oh right... i need to pull my finger out and get my rebuild done!!!
milez
Mon Nov 27, 2006 10:05 pm
Hi m8, fitted H+R to mine , should be on the road for weekend. Give u a shout and take u 4 a spin( literally) and see wot u think of them !
Cotty
Hartge Crew
Mon Nov 27, 2006 10:10 pm
fuzzy wrote:are you not concidering bilsteins? .
If we are talking about different makes then the KW set I have are very hard, probably too hard for most people. I dont know what the kit is but its probably more of a track set up rather than fast road.
If you have fillings its probably not the kit for you :wink:
Templ8e30
Mon Nov 27, 2006 10:42 pm
That's with the old sachs gas dampers and 320i skinny front struts.
I'm still using the eibach pro-kit springs that were on when that pic was taken.
Cheers,
Iain T
M5pilot
Tue Nov 28, 2006 10:34 am
Your setup is FK isnt it? Not KW.
Sal
TW166Y
Tue Nov 28, 2006 1:06 pm
milez wrote:Hi m8, fitted H+R to mine , should be on the road for weekend. Give u a shout and take u 4 a spin( literally) and see wot u think of them !
how low are they dude? i idealy need my setup for this weekend though :cry:
M5pilot
Tue Nov 28, 2006 4:17 pm
You'll be able to get the Cup kit but not sure on the Koni's.
Why is no one taking into consideration the KW suspension kits?? These are excellent aswell and a little cheaper than the H&R's.
Sal
TW166Y
Tue Nov 28, 2006 6:29 pm
M5pilot wrote:You'll be able to get the Cup kit but not sure on the Koni's.
Sal
sal i pm'd you dude asking for help but i got nothing back from you, that was about 4 days ago now :cry:
I need a setup that will allow me to go quite low for the euro look, but at the same time, the shockers must be firm enough to stop the car from bouncing the arches onto my tyres.. i know coilovers are the best option but at this moment in time i dont have £1000 to spare :cry: Ive also gotta take into consideration of the extra weight thats gonna be up front... Idealy i want to drop it 40mm and im hoping the extra little weight from the m30 lump will push the springs down a little more to acheive a 50mm drop (crossed fingers) either way if it stays at a 40mm drop it wont be too bad.
on the rear there is no way on earth ill get my 9j's under the arch with a 60mm unless i have really heavy arch mods, but it would look awsome at the same time. For practiclality, a 40mm will be just enough i think. How good are the kw shocks sal, firm enough?
Tue Nov 28, 2006 6:46 pm
If your bunging a big ol M30 under the bonnet id have nothing less than adjustables Twigg.
Ive just fitted some inverted Billies to the front of mine and they are a hundred times better than the standard 325i Gas Bilsteins, even though they were brand new 3 months ago the front end had more 'bounce' than it should
TW166Y
Tue Nov 28, 2006 7:52 pm
adjustable shocks dan? i had the spax ones last time and they were really poo. i just hope they will be better than the spax setup. this is why im not so quick to lash my cash out so quick, like i did before. i want the right stance, not too high and certainly not to low. 9j's are a pain in the ass but i can work around that. i just want to make sure 40mm is low enough with my rims, dont want no nasty black holes inbetween my tyres and arch 8O
milez
Tue Nov 28, 2006 8:38 pm
Mine are 60/40.Front sits just right for me with 2.5 lump in there. Rear has bout 15mm between tyre and arch, i'd rather have it lower , but it might give u enuf clearance 4 u r 9's.
TW166Y
Tue Nov 28, 2006 9:23 pm
sounds nice milez.. ill have to take a look at that with you only being around the corner and all winkeye
