** HELP** Throttle Sticking ** HELP**
bronk
Post Fri Nov 24, 2006 8:29 pm
when i press the throttle rite to the floor..the pedal sticks ...but if i put pressure on it ro the right of the pedal it comes back up
WHAT CAN I DO TO STOP THIS :(
help!!! :cry:
Post Fri Nov 24, 2006 8:37 pm
Fraying throttle cable is the obvious answer, but get down into the footwell and make sure the pedal assembly isn't catching on anything.
bronk
Post Fri Nov 24, 2006 8:43 pm
how do ya fix the thrrotle cable.. it only started 2day.. first time its ever done it
Post Fri Nov 24, 2006 8:47 pm
bronk wrote:how do ya fix the thrrotle cable.. it only started 2day.. first time its ever done it
You don't "fix" it - you change it.
bronk
ill get my mechanic to look at it 2moro
how much is a new one?
Sooty
Post Sun Nov 26, 2006 12:08 am
Had a similar problem with mine recently.
Checked the usual things out....ICV, MAF, throttle linkage, etc.
Eventually found that the mat on the driver's side was resting on the gas pedal & stopping it coming all the way back.
DOH !!! :o:
maxfield
Post Sun Nov 26, 2006 12:15 am
hopw you get it sorted could cause a problem i.e crash
had it on a go kart before in spain i was scared was makin my laps faster tho
**BANNED**
Post Sun Nov 26, 2006 2:16 pm
I trapped the throttle cable in the rocker cover/head joint,gave me full throttle and a cracked rocker cover...
