help! i can smell petrol in my oil
snoops
- Major Helmet
when i checked my oil it doesnt smell like oil it smells strongly of petrol?
johnono
if youroil is old / black it will have residues from combustion, as it is afterall used to lubricate insige the bores
if you notice blue smoke on ignition then i would consider having the head off and changing the piston rings
gcorky
- Boost Junkie
snoops
- Major Helmet
it is quite black and i also have an oil leak i think cos there is a puddle of oil under my car but the oil doesnt seem to be going down? can any1 help?
snoops
- Major Helmet
the car runs fine it smokes quite a bit cant really say any change in cold weather but it chugs a bit and cuts out sometimes
gcorky
- Boost Junkie
snoops
- Major Helmet
which oil wouldyou recommend for 1988 325i 136k
snoops
- Major Helmet
dont know when it was changed as i bought it a couple of days ago
Nelly
- Gumbo
Fully service it mate - oil wise, i use Magatec 10 / 50 though this can cause some old engines to run quite tappy, if this is the case drain it again and use 20 / 50
Smoke could also be down to the valve seals in the head being in need of changing because of wear - if your gonna do this, you'd be best off buying a complete head set from BMW and doing everything invovled for piece of mind.
Neil.
Neil.
snoops
- Major Helmet
thanksfor the advice neilmuch appreciated
gcorky
- Boost Junkie
Globulator
Petrol in oil is 'a very very bad thing' for your engine. Change the oil.
You may want to do a compression check to verify that your rings are intact.
1986 325i 'vert, funk louder than standard.
"No Mr Bond, I expect you to tell me why your 4 litre, 282bhp sports car can't outrun some lardy old Mercs.."
Audio & electronic software: http://www.cutestudio.net
Nelly
- Gumbo
