Engine swap?
OBs
Where do E30s usallly rust? Any usual areas that I can look out for... Below rear lights in the boot?? As far as panel work goes I can sort that out its just the chassis etc im thinking about. Also as I would proberly swap the lump anyway (One day) Is a 2.0 onwards stronger with bigger roll bars and a better more strengthened chassis etc / Does seam welding help?... I would change the suspension and brakes etc anyway. Is it wrong to bucher a IS if I was to buy one?!! Cheers for all your advice OBs
pnd
they rust all over, check arches scuttle panel, sills, footwell and underside of sunroof. Ive already told you to get an early 325 chrome bumper which are the worst for rust but the best cars both aesthetically( a matter of opinion) and for performance a matter of fact.
tomtomiS
so there OBs you've been told!
Nelly
- Gumbo
Nothing wrong with butchering an IS - they all had Galvanized floors in them so there should be no rust issues in that area plus, they run on M tec suspension and brakes - including rear disc's + bigger ARB's.
Stick with a Tec 1 sport mate - seriously, the £Â£Ã‚£ you'll be spending on up-rating an IS, you'll get a real tidy Tec 1.
Neil.
Neil.
