Adjusting steering wheel / column height
Pikey
Post Fri Nov 17, 2006 9:52 am
I just cant get on with the high up go-kart style steering wheel position in my 325 :(
Does anyone else find this a problem, and has anyone moved the steering column/wheel lower down? The only way I can see of doing it is to cut the mounting bolts and fabricate some sort of adjustable mount to bring the column down an inch or two. Not too much of a problem if you're handy with a grinder / welder :)
SPADGE
Post Fri Nov 17, 2006 10:03 am
Lift the seat up surely its easier :D
Push the lever to recline the seat down and the whole seat will come up :wink:
Pikey
Post Fri Nov 17, 2006 10:09 am
Standard drivers seat was totally knackered, that's in the bin! I'm using my brother's M3 seat, which is probably the same. But even if I were to sit higher, I find I'm too close to the pedals, so moving the column down would mean I can sit further back aswell :)
SPADGE
Post Fri Nov 17, 2006 10:13 am
Pikey wrote:Standard drivers seat was totally knackered, that's in the bin! I'm using my brother's M3 seat, which is probably the same. But even if I were to sit higher, I find I'm too close to the pedals, so moving the column down would mean I can sit further back aswell :)
Yeah i saw the seat in the guys pics it was proper fecked :)
I know what your saying about the column as i find the wheel a little high and forward as well but better than even older bm's which were even more 'sit-up and beg'.
Maybe releasing the clamp holding the column up and spacing it a little may help but you won't need much as it will make a bigger difference at the steering wheel end.
bimmaman
Post Fri Nov 17, 2006 10:17 am
What steering wheel do you have on there? When I got my car, it had the crappy 4 spoke wagon wheel type, but I have fitted a tech-2 wheel now, and it isn't half as bad... you get used to it...
gazza
Post Fri Nov 17, 2006 10:36 am
wasnt an adjustable wheel an option maybe its worth scouring the breakers
Pikey
Post Fri Nov 17, 2006 10:52 am
SPADGE wrote: Maybe releasing the clamp holding the column up and spacing it a little may help but you won't need much as it will make a bigger difference at the steering wheel end.
Explain that a bit more, sounds promising :)
bimmaman, yeah it's the 4 spoke one :( Its very 'squishy'!
bimmaman
Post Fri Nov 17, 2006 10:59 am
Yeah mine was! You could twist the grip right round the wheel! Get a tech-2 wheel mate, they make a hell of a difference... failing that, I got a tech-1 wheel for sale, which isn't any larger in diameter... see the link by my sig...
Morat
Post Fri Nov 17, 2006 11:08 am
Pikey, how tall are you?
Pikey
Post Fri Nov 17, 2006 1:11 pm
Im 5'10. Bimmaman, might take you up on that offer :D
bimmaman
Post Fri Nov 17, 2006 2:54 pm
Pikey wrote:Im 5'10. Bimmaman, might take you up on that offer :D
No worries dude, just PM me if you are interested...
oze30
Post Fri Nov 17, 2006 5:29 pm
i think the non europe/uk market may have got the adjustable colummn. I remember my pafrents chrome 325e having an adjustable jobbie
