Mounting drivers lower trim to steering column
FlashBastd
The drivers side lower trim on my car is mounted into two guides against the bulkhead, and held on with 3 plastic screws at the top, but still seems to sag a little about half way along. There is a slot in the trim panel to fix it to the underside of the steering column, but when I look on RealOEM there is nothing shown for my chassis No.
Is it as simple as a screw and washer? Or is it something cleverer?
Thanks!
Thanks!
1993 E30 318i Lux Auto Touring - SOLD
2001 Ford Mondeo 2.5 Zetec-S 5dr - SOLD
2004 Lexus IS300 Limited Edition Auto - SOLD
2005 Honda CR-V 2.0i Executive Auto
2001 Ford Puma 1.7i Black
dazleeds
- old skool raver
there should be a plastic twist type screw in the slot you mentioned goes thru slot and into steering
column then push hard and twist to lock
no more sag
no more sag
www.oldskoolfantasy.co.uk
FlashBastd
Any idea of the part no? Or does anyone have one knocking about?
Simon
Pinch one from the plastic cowl that covers the back of the headlights.
FlashBastd
Is that was is supposed to be there?
eko
- Old timer
Its what ive got in mineFlashBastd wrote:Is that was is supposed to be there?
jon_pure_british
i hate my one, it falls down most of the time, also prevented me from lifting my accelerator pedal once
Clacton-On-Sea
Essex
Essex
I've seen the slot in the trim panel, and I've seen the matching slot in the underside of the column, but I've never seen any clip fixed here. Trim should be held up at the front by a plastic bracket on the bottom of the steering column and a three pronged spring clip above the accelerator pedal. Also hooks over the heater outlet a little.
Chris-W
d6dph
Mine came with the twist fastener, not sure if it was originally there but works a treat.
Rosc0PColtrane
Mine stopped my foot too. Eventually got knackered. So I roke the bottom part of it off and haven't replaced it. It's fine now!!
orangecurry
the things I do...
top one is from the plastic headlight cowl
centre is the 'normal' trim fixing
bottom is the one you don't have, and that Brian has never seen
....and no this isn't a spare - I've just dismantled my car for the photo
jcjdavis1
Hi they are cheap at the stealers as I had to replace mine.
dazleeds
- old skool raver
yep first one in orangecurry,s pic is what i always use
Morat
Yeah, I need a set too :/
bmwe30mtech
I use a small bolt with a nut and washer on it. Tidy and strong.
