obc problems(engine wont turn off)
gazza
Post Mon Apr 04, 2005 12:13 am
i have just done a retro fit on my cab all was well untill i turned the engine off and it carried on running i disconected the plugs behind the dash and it switched off........both connectors behind the dash plug into the block and i was led to believe you cant plug them in the wrong place
one is green the other white anyone got any ideas as to what is wrong
i know this has been posted before but people often post replies with abbreviations and it has left me confused
ps i know what a obc is though
E30Mark
Post Mon Apr 04, 2005 12:39 am
I would like to know the answer to this one too! had the same problem in my car, i had forgotten about it till now :D
PM for details
Kedge
Post Mon Apr 04, 2005 11:31 am
I had this problem when i fitted mine, appparently those two wires going into the control box are something to do with the code function. So unless you really want to use that feature i would just leave those wires unpluged.
If you do want the code function, i've no idea how to solve the problem :lol:
Instagram - Kedge85
gazza
Post Mon Apr 04, 2005 11:58 am
thanks for your help i would still be interested to find where the 2 wires connect the dash is all out at the moment so i will have a play..........
come on .......someone must know out there where do these 2 wires connect
gazza
Post Mon Apr 04, 2005 7:23 pm
also does anyone know also what the single plug is for about 6inches from the obc itself (6 inches from the green plug)
E30Mark
Post Tue Apr 05, 2005 7:28 am
gazza wrote:also does anyone know also what the single plug is for about 6inches from the obc itself (6 inches from the green plug)
Does it have a black wire? If so i believe that goes to the indicator stalk, assuming you have the stalk with the pushy in end for use with the OBC.
PM for details
gazza
Post Tue Apr 05, 2005 9:52 pm
no the one for the stalk on this loom is blue evn though the wiring diagram says it should be black......the obc works well but i have left the green conector off if i connect this i cant turn the car off
