m30 afm
nickso
Post Thu Nov 16, 2006 6:05 pm
who on here is running their m30 with out an afm? ive seen a pic of someone on here without one but i cant remember who
i suspect mine is faulty and i was thinking about ditching it.
what needs to be done to get rid of it?
ta
nick
'88 e30 328i M52 track bint.
Ant
Retired Team Member
Retired Team Member
Post Thu Nov 16, 2006 6:44 pm
Andy 335 is running without AFM, he has emerald engine management to enable it though dude
nickso
Post Thu Nov 16, 2006 7:28 pm
thought it might be different management.
is this going to break my one remaining arm?
Ant
Retired Team Member
Retired Team Member
Post Thu Nov 16, 2006 7:41 pm
Emerald is c £900 if you fit it yourself( mapping is covered iirc )
you can achieve the same end result ( no AFM or MAF) with Megasquirt for under £200 if you can solder, or buy a fully built kit from someone reputable ( me :wink: ) inc a basemap and loom and have the wholse thing running for £500 ish.
not a cheap option, but arguable worthwhile ( we got 18% torque increase from loosing the AFM on an N/A M20B25 and 8% HP right through the rpm range )
gareth
Post Thu Nov 16, 2006 7:56 pm
am i right in thinking fuel economy can be increased as part of the more advanced management? or is this really just dreaming?!!!
Andy335Touring
Post Thu Nov 16, 2006 8:37 pm
gareth wrote:am i right in thinking fuel economy can be increased as part of the more advanced management? or is this really just dreaming?!!!
It depends on the tune/maps.
I think Ant says he's had good MPG on the MS equiped cars he has tuned
gareth
Post Thu Nov 16, 2006 8:50 pm
i suppose if you have full control over everything on the management side, much better economy could be achieved (if that was the main objective) rather than power. but that would be silly!
Ant
Retired Team Member
Retired Team Member
Post Thu Nov 16, 2006 9:17 pm
Ahh, but you can have both dude
Map to best power/delivery whatever you want to call it, then add variables that allow for a lean cruise situation and save a fortune
so, example, MAP to 13.1:1 AFR for "best power" then if the TPS signal is unchanged for , say 3 seconds you get the ECU to "look" at the Lambda feedback, then revert to closed loop fuelling until TPS changes again.
In theory you could use a rough map of values, fit a wideband 02 sensor, closed loop the entire range of the engine, and allow a 25% 02 trim function, in practise you cant as if the 02 fails, so does the engine, exceptions are ECU's with "fuzzy logic" that can kinda self learn and retain the trimmed settings as trims to the basemap, modern cars from 01 onwards use this technology, and revert to the safe basemap to limp you home if something goes pear shaped.
make sense ?
gareth
Post Thu Nov 16, 2006 9:27 pm
mostly!!! i must get my car sorted with some of this extra brainyness (me too!) at some point. i reckon a supercharged LPG fed M30 would be a laugh!
cheers ant!
sorry for the off-topic by the way........
nickso
Post Thu Nov 16, 2006 9:53 pm
Ant wrote:Emerald is c £900 if you fit it yourself( mapping is covered iirc )
i can solder and im not bad on wiring and stuff but i wouldnt have the first clue about mapping.
is this something i could get from yourself and just fit it and go? or would there be a huge amount of tweaking.....bear in mind im probably about as far away from your area as its possible to get, popping round for a remap is pretty much impossible. £500 ish sounds reasonable to me for the sort of gains im possibly going to achieve. £900 for emerald is too much for me i think
