Alpina 2.7 (re-build)
Wilson325i
Post Thu Nov 16, 2006 1:57 pm
hello peeps?? as am car less now i would like to re-build my alpina 2.7, change the cam from standard alpina cam to a higher one 288/272 or is it 272/288? and put in new valves etc,
now, the bottom end i can not understand, are all the bits like big ends, bearings, piston rings, the same as a 2.5 or for the 2.7 eta? or are they any special make?? :( :( :( what do i ask for when i go to order the bits
please help
Andyboy
Alpina Colada
Post Thu Nov 16, 2006 4:37 pm
It depends on whether you have a genuine Alpina engine with the forged steel crank or a 2.7 Eta rebuild. The Alpina's crank came from the 2.4 diesel engine for which BMW no longer supply bearing shells. In fact, BMW have stopped selling shells for all their diesels for some reason. Instead you either buy a set of 6 conrods with the shells or a crank with shells.
I'm not 101% sure if standard 325i shells will be okay and the Alpina parts catalogue doesn't list separate bearing shells - just a crank with shells and it's a standard 324td part number. A 325i used a grey cast iron crank and shells designed to run with that might not be compatible with a forged steel crank.
I would find an engine machine shop that lists a specific bearing shell for the BMW diesels and the later M51 units found in the E34/E36 and E35 325tds and 525tds is the same bearing. The rods themselves are the same as the 525e/320i/323i and the connecting rod bolts are stock M20. Disels run a vastly higher compression ratio and the force applied on the bearings is much higher so it stands to reason that a diesel bearing will be tougher. Euro Car Parts list a bearing shell set for the 2.5 M51 diesels for around 200 quid.
As for pistons rings, these are standard 325i. Clean up a piston top and you'll see the exact pistons size stamped into the crown - it's best to get genuine BMW rings.
Good call on the cam btw - that'll go a lot better.
Wilson325i
Post Fri Nov 17, 2006 1:41 pm
oh dear, not what i was expecting to hear 8O
what if i go to alpina themselves, do you think they would entertain my M20? :?
Andyboy
Alpina Colada
Post Fri Nov 17, 2006 5:12 pm
Nope! Well, yes if it was a genuine engine and you've got £4000 to spare. To be honest standard 325i shells will do the trick. Apparentl
oze30
Post Fri Nov 17, 2006 5:15 pm
How much do you want for the cam?? is it a torque monster or a high rev cam?
Wilson325i
Post Fri Nov 17, 2006 8:17 pm
Andyboy wrote:Nope! Well, yes if it was a genuine engine and you've got £4000 to spare. To be honest standard 325i shells will do the trick. Apparentl
nope i do not have 4k to spare, but what i ment would alpina sell these bits to me? not for them to do the work.
and i just spoke to nigel of bexley, and he told me what you just said, that standard bits should be fine :cool: so come monday am going shopping lol.
oze30 wrote:How much do you want for the cam?? is it a torque monster or a high rev cam?
its the torque cam, buy am afraid its not for sale, will be keeping it just in case 8)
oguz327
Captain Armco
Captain Armco
Post Fri Nov 17, 2006 9:35 pm
Good call on the cam btw - that'll go a lot better.[/quote]
Are the ECP ring's that much worse that the genuine BMW ones?
Anyone have a price on the rings from the stealers?
oze30
Post Sat Nov 18, 2006 11:15 pm
Buggar. Do you know what the specs are?
oguz327
Captain Armco
Captain Armco
Post Thu Nov 30, 2006 11:20 pm
Hows the rebuild going Wilson?
