Hardtop question.
bmwonly
Unapproved Trader caution
Post Sat Nov 11, 2006 7:07 pm
Could any1 tell me what an e30 hardtop is worth second hand?? its black vinal. also can you pull this vinal off and have it sprayed the colour of the car?? if not any want a hard top or want to do a swap, not bothered the colour.
Chris-W
Post Sat Nov 11, 2006 7:16 pm
I've never done it, but they are tricky to prep for spraying as there is a slight, but perceptible, honeycomb texture to the bare roof surface.
As for value Ԛ£750 - 1100 depending on condition (and demand).
blingsta
Boost Junkie
Post Sat Nov 11, 2006 7:19 pm
Agreed with Chris. ive seen these go for as low as Ԛ£600 but very rarely. what do you want to swop for?
bmwonly
Post Sat Nov 11, 2006 7:21 pm
well i would like to have the hard top the same colour as the car. if it turns out that i cannot get this 1 sprayed then i would be looking to sell or swap for 1 that is sprayable.
do the hardtops that come without vinal have this honey comb texture too???
Gouki
Post Sat Nov 11, 2006 9:03 pm
there's 2 types the Weismenn and the Original OEM BMW. Both these can be sprayed to colour code. But will require a lot of work and prepping to get the desired results.
SHAZ325iSPORT
Post Sat Nov 11, 2006 9:09 pm
i have a clour coded one,wouldnt mind swapping,call me on 07903717333 only if you have the original one and not the wiseman one.
