Can anyone let me know also where i can find more info on the M50 transplant i.e. pro's & cons, parts needed,which exhaust manifold ? etc.....
M20 2.7 or M50 2.8?
DADDG
Hi
i own a E30 325i convertible and i have a real dilemma 1st of all what i'm after is 200+ bhp 2nd Reliability! so here goes, what do you all think is the best conversion M20 2.7 or M50 2.8 ?. I'm swaying towards the M50 mainly because it seems to me more value for money?
Karan
defo more value for money... but if it wasnt an option id have a race spec m20 2.7 on throttle bodies etc
m-dtech
- Unapproved Trader caution
m50 2.8 will give better fuel consumption and similar performance.
m50 is lighter than m30
m30 has slightly more torque but heavier so not sure if it would make much of a difference.
oze30
He ewants M20 not 30!m-dtech wrote:m50 2.8 will give better fuel consumption and similar performance.
Karan
no one said anything bout m30???
DADDG
Thought about m30 3.5 conversion just for simple ease but as you said fuel consumption and similar performance would be on par with m20 2.7 and m50 2.8 edges it for me at moment
Gunni
M30 doesnԚ´t waste alot of fuel in a E30,
I did 10.8/100kmh the other day with one,
DADDG
has anyone bought the anything from zionsvilleautosport.com apparently they have full step by step conversion on cd called project orca?
m-dtech
jonb
if your prepared to convert to the m50 then forget the 2.7.
a 2.8 m50 will piss all over the funny money 2.7. so will a 2.5 m50 by the looks of it.
2.7 is a great motor when done properly, but doesnt give much gain for the Ԛ£Ã”šÃ‚£Ãƒ”šÃ‚£.
bigdek
2.8 is m52 is it not
WillG
i think it depends on if you want to do a conversion or rebuild
Ant
- Retired Team Member
Good call Will !
the 2.7 is the only option to include a complete engine rebuild, might be worth bearing in mind when pricing those M50/52 engines, dont forget you'll need a matching gearbox for the 24V engines, and a taller(lower ratio ) final drive to get the best from them
Still not an M50 fan, they just luuuurve to pi$$ oil out all over the place
Email FTW
Are you pointing out similarities Ant?Ant wrote:they just luuuurve to pi$$ oil out all over the place
Ant
But of course, just the leaks are easier and cheaper on the M20
seriously though, nothing leaks more oil than a tired M50, cam chain tensioner and profile gasket anyone ?
Email FTW
Changed the sump gasket on mine after id fitted it in the E30,
Never again
The fibre gaskets used on the early engines are absolute crap, updated gaskets are steel
Never again
m-dtech
im going for the m50 conversion
sourcing parts as we speak
Andyboy
- Alpina Colada
M50 is easier than you think. The way to go is a Ԛ£250 ebay 525i with a decent dry engine, M20 flywheel and clutch and bog standard M40 318i gearbox. This bolts straight onto an M50, costs about Ԛ£30 to buy and because it's an 0.81 overdrive means you don't need a different diff. You can also use a 320i prop, another worthless item. The 318i box is pretty strong and providing you don't kick the living shit out of it will tolerate an M50 okay. The E34 525i radiator also drops straight into an E30 with no mods. I'm sure the 525i downpipe can be mated to an E30 centre box with some deft modding.
The M50 is 192 bhp from the box, 200 bhp with a chip. If you get a J or K plate non vanos unit it's 2 hours max to lift the lid and drop a pair of Schrick cams in for 220 brake - never mind all this M20 drama of removing the head and punching old rocker shafts out. The M20 is just old, old news and when you can buy something so superior for peanuts - why bother? As for oil leaks, I beg to differ - the M20 is a shocking thing for oil leaks, the front cam oil seal being a prime suspect as well as the cam cover and the four rubber half moon seals.
Do it the above way and you could have it in the car running and driving for Ԛ£500. Then so sell all the remaining E34 bits on Ebay to get some of that back. Buy an H plate 525i and you might even be lucky enough to get the early one with the overdrive Getrag 260 box attatched.
A 2.7 has it's place but to get 200 bhp costs a lot of money.
DADDG
m-dtech
i thought the vanos was the m52 units ??
DADDG
what are the differances between a M50 & M52 except for cc
M50 - 2.5 - Non-Vanos or Vanos - Iron block
M52 - 2.5 or 2.8 - Vanos - Alloy block
If you drop an M50 into a RHD E30 you will need to fabricate a manifold/frontpipe to mate up to an E30 centre box
DADDG
DADDG wrote:Hii own a E30 325i convertible and i have a real dilemma 1st of all what i'm after is 200+ bhp 2nd Reliability! so here goes, what do you all think is the best conversion M20 2.7 or M50 2.8 ?. I'm swaying towards the M50 mainly because it seems to me more value for money?
DADDG
jmc330i
BTB is meant to making a 6 branch manifold for an M50 conversion, but that is also suitable for the S50 engine, but Im not sure how far its got.
TBH I cant see how it will work well for both M50 and S50 engines, but they are the experts.
As for 2.7 M20 or 2.8 M52 - its got to be the 24v conversion (either 2.5 M50 or 2.8 M52). As has been said, its a cheaper way of getting 200bhp and youre not getting involved in an engine rebuild.
James
'91 325i Sport
'93 318i touring 16v
'91 325i Sport
DADDG
m-dtech
i have been looking at some power figures between vanos / non vanos 2.5 and 2.8 m50 engines.
id personaly go for an early non vanos 2.5 and consider turboing it at a later date if more power was desired.
take a look at
http://www.bmwworld.com/engines/m50.htm
difference between 2.5 and 2.8 is pitiful (in standard tune)
take a look at
Dan318-is
The reason the m52 has such bad figures is because it was restricted from the factory so it had a lesser performance than more expensive models in the range. with a m50 throttle body and manifold an d remap they can see 225 brake in standard form; the alloy bock is also a lot lot lot lot lot lighter than cast iron anchor that comes with the m20/m50 imho; i think if i was going through any hastle whatsoever to install something like this in an e30 i would make sure i did it properly; put a light m52 in there, spend a couple of hundred tuning it and piss over most conversions out therem-dtech wrote:i have been looking at some power figures between vanos / non vanos 2.5 and 2.8 m50 engines.
take a look at
m-dtech
225bhp after the hassle of wiring up vanos etc, pissing about with re maps. for 35bhp more than standard 190bhp from 2.5 non vanos....
id rather spend on turboing 2.5 non vanos and get near on 300bhp
DADDG
Dan318-is
yep then you've got the hastle of either a) paying around 800 quid to get standalone management and a re-map or b) the hastle or wiring and mapping megasquirt to deal with the turbom-dtech wrote:225bhp after the hassle of wiring up vanos etc, pissing about with re maps. for 35bhp more than standard 190bhp from 2.5 non vanos....
The bolt pattern is the same but there are some serious hurdles to get over.DADDG wrote:i've been looking through a few bmw sites at E30 conversions and apparently a E46 320d 6 speed gearbox will mate to M50/M52 using M54 clutch no problem is this possible
Gear linkages needs shortening (wait till you see it in standard form), you will need a custom prop, spigot bearing needs a carrier machining to bring it out into the gearbox
Thats as far as ive got, the gearbox support needs modding to fit the E30 tunnel, clutch is a PITA, the new gearboxes use a different input shaft spline with about twice as many teeth, because the boxes are so recent there are no spurious clutches so its a dealer only part ATM.
Ԛ£150 just for the centre plate
Heres a couple of pics of the linkages just to put you off
Both need shortening by about 50mm
m-dtech
yep totalyDan318-is wrote:yep then you've got the hastle of either a) paying around 800 quid to get standalone management and a re-map or b) the hastle or wiring and mapping megasquirt to deal with the turbom-dtech wrote:225bhp after the hassle of wiring up vanos etc, pissing about with re maps. for 35bhp more than standard 190bhp from 2.5 non vanos....
id go for option B its going to see more power
oguz327
- Captain Armco
I am still not convinced about the m50/m52 conversion, some of the options will still cost nearly 2.7 money unless you are very good with a spanner. What are the torque figures for these engines?
Personaly i will be going for the oldskool tryed and tested 2.7. Sounds awsome, easy to work on, you get a rebuilt engine and it will drop straight into any 6 cylinder e30 with hardly any mods.
DADDG
