2.5-2.7
whippy
Post Wed Nov 01, 2006 8:37 am
eta 327 vs alpina 327?!?!?!
No contest, my pina would kick an eta conversions ass any day!!!
Just look out for a genuine alpina lump (& manifold if you can), one went for only Ԛ£400 on eBay not too long ago.
Stuff 2.7, if you are going to build one yourself, it's easier to go for 2.8 if you have a M20 2.5 engine to start with :)
oze30
Post Wed Nov 01, 2006 10:48 am
And how would you go and do a 2.8?
AFAIK, the way i'm doing the 2.7 is almost the same. just difvferent cam... so i don't see how your's would kick ass over a proper conversion??
whippy
Post Wed Nov 01, 2006 2:14 pm
I've made a 2.8 out of a m20, now working on a 3.1. Quite easy when you know how. lol
We should go to a santa pod meating and put yours against me pina :D
oze30
Post Wed Nov 01, 2006 2:22 pm
I'd rather not thrash the crap out of my car and bust some driveline while i'm at it thankyou. I'm very sympathetic to my car
HOW did you do the 2.8? and how you doing 3.1? very interested as I may decide to change my capacity
whippy
Post Wed Nov 01, 2006 2:32 pm
I made it up out of parts I had lying around. Trial and error, lol.
I know 100% what the grank and pistons are from, but only 70% sure where the con rods come from. As soon as I know, I'll be puting a full article on here. Watch out for it. :wink:
P.S how do I make my image smaller?!?!
ian325is
Post Thu Nov 09, 2006 9:26 am
To convert a 2.5 to 2.8 you just use the crank from an E36 328 M52 with 130mm rods from eta or 320. Some simple machine work neccesary to nose of crank. 325 pistons will need 11-14mm machined off the bottom to clear crank. Same story with early 325 pistons and 2.7 crank. Block can be used as is.
For the 2.7, the block will need to be decked 2mm regardless of which pistons you use. It is the length of the piston skirts that are different.
oze30
Post Thu Nov 09, 2006 4:15 pm
Whats the power diff between 2.7 and 2.8?
Ant can you call or pm me re: 2.7 build.. IUm starting to get lost in translation here re: cam
Cheers,
0782 108 7679
Post Thu Nov 09, 2006 10:03 pm
Genuine alpina lump for Ԛ£400 i'd like to see that!
there was a certain les stannard built 2.7 eta which was on this forum which would hand an alpina 2.7 it's arse
Alpina's need a better cam really to finish them off
3.1 M20? i bet thats going to rev well :?
ian325is
Post Fri Nov 10, 2006 7:34 am
3.1 is not such a good idea. Conrods will be too short in relation to the cranshaft throw resulting in huge piston slap.
Andyboy
Alpina Colada
Post Sun Nov 19, 2006 3:19 pm
ian325is wrote:3.1 is not such a good idea. Conrods will be too short in relation to the cranshaft throw resulting in huge piston slap.
I think it's bullshit anyway! It can be done using a 3.2 Evo M3 crank and rods with some weird Bike pistons.
I did a 2.8 M20 3 odd years ago. The crank doesn't need machining but you need to make a spacer for the nose of the crank fore the M20 crank oil seal to sit on. I used an M52 centre pulley hub and turned it down in a lathe. For some reason it was a pretty tight fit on the M20 crank (a tap fit as opposed to just sliding on) but i got around the possibility of it turning by drilling and dowelling it to the front crank pulley.
The advantage of using a 2.8 crank is that the stroke is longer - using 325i pistons and Eta/320i rods the pistons come perfectly to the top of the bore so unlike the 2.7 stuff you don't need to mill 1.5mm off the top of the block.
The engine I built is in Adams car. Using early 325i 9.75:1 compression pistons and it has a CR of @10.7:1.
bmwscorpion
Post Wed Dec 20, 2006 6:07 pm
Ive just read all the way through the posts, when the engine is fitted with Zone 2.7 chip which AFM shall I use 320 or 325? .. or is there a difference.
Belive it or not Im building my 2.7 outside in the fog and minus tempratures today, it is nice to be inside..
oze30
Post Wed Dec 20, 2006 8:45 pm
bmwscorpion wrote:Ive just read all the way through the posts, when the engine is fitted with Zone 2.7 chip which AFM shall I use 320 or 325? .. or is there a difference.
Id say use the biggest you got.. so 2.5
