think thats the best way to describe it,
1989 325i se took the universal joints apart today to check for play and there isnt any, but the shaft thats part of the loweruj doesnt fit snug in the upper uj, should it?think thats wherethe "clonk" is coming from
what does anyone think?
cheers tim
clonk when steering
ric325i
cant answer you question but i had a strange clunk from the steering yesterday!
i had been playing with things checking them over and had removed the lower plastic shelf / guard.
and when replacing it i had not put that back on far enough forward and was catching everytime i put full lock on and off.
i worried lots and then realised.
laughed lots.
its the simple things.
good luck hope someone can answer your Q! sorry that was no help i just thought it was funny.
jon_pure_british
have you tried jacking it up and had someone steer for you whilst you take a butchers?
Clacton-On-Sea
Essex
Essex
timmyboy
timmyboy
Dan318-is
CJ joints will hardly ever fail on an e30; iv never seen them fail.
I would check both inner and outer ball joints for vertical movement;
another possibility is the anti roll bar links attatched to the wishbone; if the bolt holding them to the wishbone is threaded there is always an aweful clunking sound i find.
Ball joints/wishbones would be my first port of call though fella's.
