Were they made in South Africa then?
Its the aircon that temps me most
i would be the opposite - if you can find one grab it - no rust issues due to the climate!!dobbie82 wrote:I have seen a few south african imports for sale, though 2 of them had chrome arches and i wouldnt touch with a barge pole!
Its the aircon that temps me mostBut were the bodies galvanised or do they rust just as much as the UK models?
Sorry post edited now, i meant i wouldnt touch one with chrome arches as you dont know whats underneath.eamo wrote:i would be the opposite - if you can find one grab it - no rust issues due to the climate!!dobbie82 wrote:I have seen a few south african imports for sale, though 2 of them had chrome arches and i wouldnt touch with a barge pole!
slightly offtopicboomer wrote:They're not better than the UK ones - just specced up differently I think.
Rust is rust - On my 320 (built '89, imported '91) all 4 doors have rusts, sills & F/R arches are showing spotting and the sunroof panel has a spot.
Mine has beefed up suspension - a curious combination of mtech arbs, very stiff springing and 45mm front struts. And it had a sumpguard fitted.
The radiatior is bigger than UK spec as well and the air filter box takes an M3 sized filter panel (the filter box has a rubber valve on the bottom of it for letting out sand and dust).
They may have aircon fitted which is good....if it works, and a pain in the ass if it doesn't work (the old lady who sold me mine said she'd never had the aircon on since importing it - didn't need it in this country)
Mine also has cruise control fitted which is a very good thing if you do mucho miles on M-ways
Other than that the interior may be different - mine has comfort learther seats with vinyl door cards
And the speedo will read in kmh rather than mph
And it have a check computer that has a seatbelt warning sign![]()
I know they were built in SA but I don't know where.
HTH
i had noticed your in the past !!! but think you need to close your bonnet fullyYou think the Ausy ones are good you should see the Kiwi ones
My turbo is sooooo massive it wont close lol, na we just had the bonnet offmrLEE30 wrote:i had noticed your in the past !!! but think you need to close your bonnet fullyYou think the Ausy ones are good you should see the Kiwi onesor adjust the catch!!!
Thats the SA 325iS - its what the UK 325i Sport should of beenCiLK_WuRM wrote:My SA spec car came with M3 suspension and brakes, a 2.7 and some nice aluminium alloy panels. Result
you can probably credit that one on a Mr Foster, buyer at the Rosslyn plant in the late eighties... you should have seen some of the gear he got given as "thanks for the business Foz"Seat belts are different , can't plug a SA belt into a German catch or visa versus
Interesting...CiLK_WuRM wrote:My 325iS has both P/S and A/C.
Its got the rear plate filler too.
Thanks a lotian325is wrote:That sounds about right. I.ve got the specs and road tests somewhere. Will have a look and see what I can find.
