My 325i won't rev. NOW Solved thanks to all
grimbleweed
Post Wed Nov 08, 2006 8:40 am
Hi - Have 325i 1986 - completely original and in good nick - have owned for 15 years. Suddenly lack of power - wont rev above 3000 when driving. Any ideas?
buster
Post Wed Nov 08, 2006 8:47 am
Probably airflow meter,maybe a bad airleak
Daadji
Post Wed Nov 08, 2006 11:23 am
Airflow meter definately
Steviec
Post Wed Nov 08, 2006 11:26 am
Check the electric plug that connects to it and also check the pipe from the AFM for any splits on the underside.
I have a spare afm if the above doesnt work.
<a><IMG></a>
grimbleweed
Post Wed Nov 08, 2006 1:43 pm
Thanks lads - will investigate - can they be cleaned?
grimbleweed
Post Wed Nov 08, 2006 10:48 pm
Had a go this evening - here's what I did.
Replaced all six sparkplugs - just in case.
Removed air filter - sprayed carb cleaner up into the AFM whilst engine was running and also into the idle valve.
DID'NT replace air filter - although it didn't look very dirty - car has been standing for 4 months. Left it out then -
Took for a spin
WOOOOOAAAHH - this is how i remembered car years ago.
Then I replaced original air filter, car was slightly better than before - but still sluggish under power,
Tommorrow off the Halfords for new air filter - I'll report back.
THANKS FOR TIPS GENTLEMEN
grimbleweed
Post Thu Nov 09, 2006 5:20 pm
Went to BMW - new airfilter - solved problem completely. Now getting that punch in the back acceleration I should.
Post Thu Nov 09, 2006 10:00 pm
grimbleweed wrote:Went to BMW - new airfilter - solved problem completely. Now getting that punch in the back acceleration I should.
May I suggest you pay a little more attention to routine servicing in future! When you said "completely original" in the OP, I didn't realise you were including the filter element!
grimbleweed
Post Thu Nov 09, 2006 10:24 pm
I'm not that silly - car has been used off and on - but filter was changed last year - only done about 500 miles - but has been sitting out since - the last thing I thought it would be was the filter!!
Car has been regularly serviced by a BMW specialist.
BTW it is original and in overall good condition. Slight rust problem to tackle quickly.
Original bottle top wheels in perfect condition, even though not garaged for 14 years.
Love it....
