e36 help
Bob_S
Post Fri Nov 03, 2006 6:43 pm
hi all, my mate is experiencing some electrical issues with his 325tds.
his rear fogs are stuck on and occationally the whole unit will switch off and the sidelights dont work either,
I suspect it might be a bad earth on the lights does anyone else have any ideaS?
Bollocks to this 24v scrap!
cliffybabe
Powered by Nelly
Powered by Nelly
Post Wed Nov 08, 2006 12:58 am
Ask Stuartgallafant he might be able to suggest something
Steviec
Post Wed Nov 08, 2006 9:30 am
Have you tried another headlight switch?
<a><IMG></a>
stuartgallafant
Post Wed Nov 08, 2006 10:10 am
i would start at the lights and work backwards. check all the connections, as the do deteriorate. also, the lights on these are controlled by a control unit called the LSZ - Light Switch Centre. if theres water ingress for whatever reason, you'll be having trouble.
and as steviec said, possible switch, although i've personally never had one go wrong!
Bob_S
Post Wed Nov 08, 2006 6:09 pm
Where can I find this LCZ mate? cheers
stuartgallafant
Post Wed Nov 08, 2006 11:14 pm
erm, damn, i havnt worked on an E36 for ages!! i think its behind the glovebox, either above or below the general module. its highly unlikely that this has a water ingress, but it may have an internal fault? it might not even be that, im just throwing ideas at you!!
you really do need to start at the clusters and work backwards
