Need help 318i to a 325i
316vinni
Post Tue Nov 07, 2006 7:51 pm
Hi all. I need a little help, ive just got a touring off Dazleeds, and i want to convert it from a 1.8 to a 2.5. I have a 2.5 engine and box, also LSD. The engine i have has the loom already on it, but its a 2.5 out of a D plate E30, its a H plate touring. I know i need a 2.0 or a 2.5 rad. Dose anyone know of aything else i will need to change?
Thanks.
Vinni.
dazleeds
old skool raver
old skool raver
Post Tue Nov 07, 2006 8:43 pm
i knew yyoud want the 4pot outter there quicktime lol
as i said pretty sure its plug n play with the loom bar feeding ecu plug thru the bulkhead
sure the engine swap experts will be along soon mate
what wheels you putting on there?? mims?
www.oldskoolfantasy.co.uk
316vinni
Post Tue Nov 07, 2006 8:47 pm
Yes the 4 pot is close to death :D , Dont know why lol. I got my mims on there now.
jmc330i
Post Tue Nov 07, 2006 9:20 pm
My 318i to 325i (both facelift cars) was a straight swap wiring wise, but there might be a few wiring differences with yours being a pre to post facelift swap. Nothing that cant be easily sorted though - calling Brianmoooore :D
One wire you may not have (depends how complete the 325i loom is), is the big wire that goes from the battery (or +ive post in the engine bay) to the starter. The 318i has a different setup to the 325i.
You will also need a 325i prop as the 318i prop will be too long and some 6cyl front springs.
James
'91 325i Sport
'93 318i touring 16v
316vinni
Post Tue Nov 07, 2006 9:31 pm
Thanks jmc330i. TBH i have a hole pre face, just not the shell, prop, rad or cluch lol. So im ok for all the 2.5 legs and stuff. Are the sub frames the same on a 318? The engine loom is complete. I just hope its like Daz said, unplug, plug in and away. :?
jmc330i
Post Tue Nov 07, 2006 9:42 pm
Sub frames are the same between 318i and 325i, so the front legs will just swap over. The 318i touring will have the 51mm front struts and same brakes as the 325i anyway, so just pick whichever are the best bits.
I did my conversion because the M40 lump broke :( Ive got to say, best thing I ever did :D
I mean the engine, box, LSD etc all came from my Sport which I drove for a couple years, but its just so much fun driving a quick touring - people just dont expect it :D
James
'91 325i Sport
316vinni
Post Tue Nov 07, 2006 9:50 pm
jmc330i wrote: so much fun driving a quick touring - people just dont expect it :D
With 318i left on the back, they get a short sharp shock :twisted:
jmc330i
Post Tue Nov 07, 2006 9:54 pm
If you do it right, dont bother with the twin exit exhaust. It saves cutting the rear valance and mine just looks like 318i with a 3" exhaust and a tow bar :lol:
James
'91 325i Sport
316vinni
Post Wed Nov 08, 2006 12:00 am
Good idea :thumb:
316vinni
Post Wed Nov 08, 2006 9:48 am
Also are the tanks, fuel lines or pump differant?
jmc330i
Post Wed Nov 08, 2006 9:58 am
The pump in your 325i maybe different with it being a pre-facelift, but the fuel pump in the touring will be fine.
My 2.5 conversion is still running the 318i pump etc.
James
'91 325i Sport
316vinni
Post Wed Nov 08, 2006 11:22 am
Thanks for your help mate :wink: If i get stuck ill give you a shout :D
