brakes jammig on ???
Guest
Post Fri Apr 01, 2005 3:35 pm
Hi Guys,
When i drove the car yesterday the brake pedal keep jamming on not sure whats up ?
Lars
RICHIE74
Post Fri Apr 01, 2005 5:47 pm
Take your wheels off and check your brakes , sounds like either pads
stuck in slides or maybe a seized caliper . Checked mine last weekend
and piston seized solid , so thats this weekends project
Guest
Post Fri Apr 01, 2005 5:55 pm
Thanks i have it booked into a garage for next week will get them to check it and i wont drive it until then and thanks,
Lars
psychochild187
Post Sat Apr 02, 2005 1:47 pm
my pedal was going down and not coming up jammed the brakes on too, this was master cylinder.
Guest
Post Sat Apr 02, 2005 2:20 pm
cheers for that mate its going for a full service and check up next week will tell them and have it checked out but thanks again for all the help
Lars
Post Sat Apr 02, 2005 8:48 pm
If the pull rod that goes across the car from the pedal box to the master cylinder is adjusted too tight it can cause this kind of problem.
Don't really see how it could happen if no one's been messing with it, but worth checking there's a little slack in the linkage.
johnono
Post Sun Apr 03, 2005 1:05 am
brian, my left side rear disc is burning up!!, it smelled funny (hot hot) and i touched it to see if it was the disc, blistered my thumb instantly :?
the disc is ridged, so im replacing them, and pads too but is it dangerous to drive with them so.. i mean it gets HOT, the others are not even warm
Post Sun Apr 03, 2005 10:14 am
Johnono, could be the handbrake binding in the drum inside the disc.
Check the hub turns OK without the pads in.
If it is the main brake causing the trouble, then check the sliding caliper guides are not seized. Failing that it's probably a sticking, i.e. corroded piston un the caliper.
Wouldn't recommend driving too far, if it's getting that hot.
johnono
Post Sun Apr 03, 2005 3:53 pm
cheers bri, sorry for stealing the thread :oops: Lars
