New Tourer!
dazleeds
old skool raver
old skool raver
Post Sat Nov 04, 2006 3:22 pm
Jesus325iTouring wrote:
gcorky wrote:
Jesus325iTouring wrote:And once you've finished your service it would be worth popping to the local garage to have the Co2 reading checked,only cost me a fiver and made a big difference to general running :D
by checking how did it affect the running....ecu controlled anyway?
I dunno what they did except stick a probe up the exhaust which gave a machine a Co2 reading then adjusted something under the bonnet.
The effect of what they did was no more eye wateringly noxious fumes when backing into the garage,by the time i had backed it in and got out of the garage my eyes would normally be watering.
The next effect was it greatly reduced the engine juddering at low speeds which is a nightmare in traffic,it also leveled out the dreadful idle.
Finally it made the engine a little bit more lively than usual.
Someone on the Zone may know what was adjusted under the hood.
id guess they adjusted the afm fella
think by the sounds of what you said before mine could do with some tweeking
will get it booked in next week :D
www.oldskoolfantasy.co.uk
Jesus325iTouring
Frog freak !
Frog freak !
Post Sat Nov 04, 2006 3:30 pm
Was definalty worth doing Daz and only takes one fags worth of time :D
dazleeds
old skool raver
old skool raver
Post Sat Nov 04, 2006 3:33 pm
dnt suppose it got rid of that slight hesitation when ya first touch the pedal??
gotta be worth the small effort as mine always smells rich and fumey
and ive done the blue sensor etc seem to remember when i got mot my emmissions were at the high end of whats allowed too :roll:
ps good to see you back mate
hasnt been the same without you
work some of your magic and get things livened up on here mate :D
Jesus325iTouring
Frog freak !
Frog freak !
Post Sat Nov 04, 2006 3:44 pm
dazleeds wrote:dnt suppose it got rid of that slight hesitation when ya first touch the pedal??
Mine was never to bad anyway TBH so not really any noticeable difference,and besides,your supposed to pull away at 5000rpm everytime so really shouldn't matter!
Will do my best to liven things up,my brains ticking over some interesting threads :twisted:
dark_sounds
Post Sat Nov 04, 2006 5:13 pm
ooo i might do this as well then, get it down a garage and have it tweeked up after i sorted everything out.
ooo interesting wager JonB, what makes you reckon its got a LSD??
right today i have:
changed air filter
dizzy cap
rotor arm half way, the allen key bolts seem to be very tight, sprayed some WD and attack it tommorow!
ended up rounding the fucking nut on the sump while getting the oil out, so cant change the oil, the mole grips dont work as its just munching into the nut,, making it rounder and rounder. anyone else got any ideas??? might post this seperatly actually.
other then that the dizzy cap looks like it was never ever changed in its whole life! (170 000)
anyway hopefull all this will make a recognisable difference :)
Directed CompX's 12"... 2off. 1000 watts RMS, dual 2ohm VC. 90£ each!!
8600 Luna Phone 480 POSTED BNIB
miniblob
Post Sat Nov 04, 2006 5:54 pm
Nice one Ali - i bet your sound system is still finished before mine - and i've had the bloody car since march!!
Tourings are wicked - proper space for bass!!!!!!!!! :cool:
327 Touring with bass!!!
Chris-W
Post Sat Nov 04, 2006 6:02 pm
dark_sounds wrote:ended up rounding the ******* nut on the sump while getting the oil out, so cant change the oil, the mole grips dont work as its just munching into the nut,, making it rounder and rounder. anyone else got any ideas??? might post this seperatly actually.
Irwin bolt extractors.
Jon_Bmw
Dangerous when thinking
Post Sat Nov 04, 2006 6:06 pm
Don't get me started on sump nuts, had one a couple of days ago that was up to 170NM's of torque, i had to jack the car up and stand on the forking wrench! Thank god it came out clean, and the ali sump was ok. Hope you get yours out ok in the end. Don't really know what to suggest now its rounded.
dark_sounds
Post Sun Nov 05, 2006 10:40 am
hmm, rounded the fuck out of it, mole grips keep eating into it,
hopefully the rotor arm bolts dont round either! cos they seem prety stuck!
bloody old cars!
Rob, yeah man, you gotta go hard core on the sounds now!
Post Sun Nov 05, 2006 10:56 am
dark_sounds wrote:hopefully the rotor arm bolts dont round eithereem prety stuck!
bloody old cars!
Nothing to do with the age of the car, or BMW engineering. Solely to do with incompetent servicing.
The sump plug has been badly overtightened, (why do you think BMW specify a torque figure?), and the rotor arm bolts, although they do seem to be made of rather soft steel, have probably also been overtightened.
Use a good quality socket type driver on these. L type allen keys put sideways pressure on the bolt and twist out.
dark_sounds
Post Sun Nov 05, 2006 10:59 am
bloody old cars!
ooh didnt know that, cool ill do that before i go any further!
mattG
Post Sun Nov 05, 2006 11:16 am
well done ali, is it coming to guilford :cool: enough tourings have our own section of the bk carpark, we'll leave the coupes & 4 doors over by the saxos winkeye
dark_sounds
Post Sun Nov 05, 2006 11:33 am
lol!
not sure working hard on getting it through emissions
ned to do rotor cap, and dizzy cap , fuel filters (theres 2 aint there??)
maybe do oil though i need a new sump bolt! so might have to wait! but oil shouldnt effect emissions too much no?
get some injector cleaner in the petrol tank, see what hapens, adjust AFM as well, but if it still doesnt pass emisiosn then ill be run out of ideas, and just be a new engine time! hopefully make it for a re MOT tommorow, and if it passes then ill be at guildford! :)
mattG
Post Sun Nov 05, 2006 11:51 am
why didn't you want a sunroof?
dark_sounds
Post Sun Nov 05, 2006 12:23 pm
sounds!!
non sunroof cars are stronger on the top. less flex, more db. :twisted: :twisted:
also happens to not have a sun roof cos its got aircon :cool:
oguz327
Captain Armco
Captain Armco
Post Sun Nov 05, 2006 12:43 pm
What colour is it Ali? we need pics dude! :cool:
dark_sounds
Post Mon Nov 06, 2006 9:03 am
well done jon b!!
the car has an LSD!
thought it was scarily good to control!!
so reminder, parts list:
Air con
cruise
heated seats
LSD
tow bar
switchable box(are they all switchable??)
not bad eh!?
pics... taken quickly just for oguz
cliffybabe
Powered by Nelly
Powered by Nelly
Post Mon Nov 06, 2006 11:21 am
nice to see ur alreay using it as a van wither ea rear bench seat stuck in there like that winkeye
Nice motor dude
Morat
Thats a fine machine and no mistake.
As for sunroofs - I'd rather not have one. If you're 6ft4 the extra headroom is welcome.
Have you changed the brake fluid, engine coolant and diff oil? Worth it now rather than later I'd say...
Post Mon Nov 06, 2006 11:53 am
MMM sounds like a typical ebay prize ! :eek:
miniblob
Post Mon Nov 06, 2006 8:52 pm
Looks sweet man!!!!!!!!!!
You know you wanna sell me that cruise control winkeye
Handy towbar - always fancied filling a whole car with subs and putting the amps out the way in a trailer!!!!!
Cotty
Hartge Crew
dark_sounds wrote: New Tourer
Welcome to the dark side :twisted:
Nelly
Gumbo
Gumbo
Post Mon Nov 06, 2006 8:54 pm
"I F**KING LOVE YOU GUMBO"
Cotty
Hartge Crew
Post Mon Nov 06, 2006 8:56 pm
dark_sounds wrote:switchable box(are they all switchable??)
Nope mine isnt :wink:
stuartgallafant
Post Mon Nov 06, 2006 10:29 pm
nicely done ali!!
dark_sounds
Post Mon Nov 06, 2006 11:13 pm
wicked another feature then!
im looking forward to working on this!
rob .. im keeping the cruise control sucker! best feature ever!
morat, def a good idea, especiall diff oil, dont want that packimng up!!
funny how a diff can be worth as much or more then a m20 engine!
Post Tue Nov 07, 2006 8:17 pm
u selling the diff anytime soon?!
Nelly
Gumbo
Gumbo
Post Tue Nov 07, 2006 8:31 pm
If he does it's to me - fight you for it Si LOL - handbags at fifty paces
Post Tue Nov 07, 2006 8:34 pm
i'm a lover u know that!
maxfield/twigger "dibs" it for you first?
dips346
London Meets Main Man
Post Tue Nov 07, 2006 10:39 pm
i have a claim on everything first boys,so carry on fighting for it as winkeye
Post Tue Nov 07, 2006 10:41 pm
i want the load cover aswell Dips but not to hide my subs, but my tools!
i didn't know u could be 6ft and sleep flat in the back of a tourer?
Cotty
Hartge Crew
Post Tue Nov 07, 2006 11:09 pm
Never tried it but handy to know :wink:
Nelly
Gumbo
Gumbo
Post Tue Nov 07, 2006 11:15 pm
dips346 wrote:i have a claim on everything first boys,so carry on fighting for it as winkeye
:bow:
dips346
Post Tue Nov 07, 2006 11:16 pm
Simon13 wrote:i want the load cover aswell Dips but not to hide my subs, but my tools!
what colour might have 1 at home if not i know ali might sell his one anyway
dark_sounds
Post Wed Nov 08, 2006 10:35 am
i know ill defo be selling my one! though dips prob got a better condition one, on mine the bracks are cracked, so if your too violent it will pop off. though behave and its fine tbh :)
priced accordingly :wink:
