whistleing noise from somewhere!!! (sorted)
blingsta
Boost Junkie
Post Fri Nov 03, 2006 10:02 pm
After removing the air intake from throttle body so i could change the O ring rubber seal from that tube that goes from the block to the inlet manifold. I put everything back on and gues what? Yep, as cars on boost, im hearing a loud whistle noise from under bonnet, sounds like the whistleing kettle on boost... WTF is that about??? any ideas? pipe off from intake ! pipe back on ! = whistle?? :x :cry:
Jon_Bmw
Dangerous when thinking
Post Fri Nov 03, 2006 10:29 pm
Sounds like a boost leak somewhere to me, turbo spinning up and leaking from somewhere, creating a high pitched whistle. Maybe somewhere to look at first, to rule it out anyway.
blingsta
Boost Junkie
Post Fri Nov 03, 2006 10:39 pm
yeah, but where do i look? all the pipes from the turbo?
Jon_Bmw
Post Fri Nov 03, 2006 10:43 pm
yeah, any pipes from the turbo to the throttle body. So i'm guessing:
Pipe-from turbo compressor outlet, to intercooler inlet
Pipe-intercooler outlet to throttle body
Dump valve T piece.
From what i can remember you don't have the crappy rubber boot that is standard on an m20 engine, so thats one less thing to look for, as they blow out quite easily.
blingsta
Boost Junkie
Post Fri Nov 03, 2006 10:55 pm
will double check all them 2moro.. Cheers Jon
blingsta
Boost Junkie
Post Sat Nov 04, 2006 11:21 pm
Yep.... on way home from work, still whistleing away... then all of a sudden, loss of power!! i though the worst.?? pulled up in juice station.. bloody pipe dropped off and hanging loose!! tightened back up, and no more whistles.. :D :D :D
fuzzy
He who sleeps with "Gingers"
Post Sun Nov 05, 2006 11:20 am
nice and easy fix :D i was racing on friday when the turbo to intercooler hose popped off at full boost,got a bit off a fright winkeye
Jon_Bmw
Post Sun Nov 05, 2006 12:40 pm
Nice to see an easy fix :) Just that bloody o ring left on the inlet mani now :cry:
blingsta
Boost Junkie
Post Sun Nov 05, 2006 2:47 pm
Yeah, thats the only bugger along with a tiny water leak from thermo housing, i changed one side of the cover as the ridges on the connection pipe were no longer ridged, that sealed 1 little leak, now ive got another from the other side that connects onto the block...
