For my second M50 project Clicky I want to keep the engine and exhaust as quite as possible, so i would like to put a standard air filter box in, instead of the K&N that i've got. Was down the breakers the other day and A e36 box is never going to fit as its to large to fit in the space I have, so just wondering if anyone else has done this and what they used? If not is there an aftermarket filter combo etc... thats not as loud as a K&N pipercross etc....
Want a proper (quite) air box on my M50 what to use?
eko
- Old timer
E34 535i airbox!
About to fit one on mine to get rid of the pipercross cone thingy
Danthe has already done this mod,thats who gave me the idea,looks good too
EOS
Lovely stuff cheers eko. Got any pics?
eko
- Old timer
Try this link -
http://66.249.93.104/translate_c?hl=en& ... soft:en-US
chu346
Where is the powersteering resivoir?
eko
- Old timer
Some use the E36 bracket to bolt the reservoir to the engine mounting!chu346 wrote:Where is the powersteering resivoir?
Mine is bolted lower down the suspension turret,just enought clearence to put the MAF pipe on
I've got the 535 one in mine with the steering resevoir in the standard position, although the feed to the pump is re routed.
Air meter fits completely inside the lid of the air box.
Heres a pic of mine
MAF inside, I had to grind the ribs of the inside of the lid and from around the MAF to stop it pushing on the filter element.
MAF needs to be as far back as possible really, as the lid of the box tapers
Sooty
Don't forget that you can't use this air-box if you've got a rad with the expansion tank on the side.
I found out after I'd bought all the bits
eko
- Old timer
Which rad are you using?Sooty wrote:Don't forget that you can't use this air-box if you've got a rad with the expansion tank on the side.
Im using a 318is one(with side expansion) and looks like plenty of room to fit,not tryed it in place yet though so fingers crossed!
Same reason im using the M20 rad, although if you look at the pics in the link to the german site you can see they are using the tanked rad.Sooty wrote:Don't forget that you can't use this air-box if you've got a rad with the expansion tank on the side.
Problem I had was the MAF pushing the filter element down because it was too far forward and the box was really close to the throttle linkage
