I need to wire up my rev counter .can anyone tell me what colour wire joins to the back of the clocks or is there a easier place to join the wire.
any info will be a great help.
rev counter
tomtomiS
in what way do u mean wire it up, there's a couple of multiplugs that go into the back of the clocks
e30cossie
I have a cosworth engine loom and the green wire is for the rev counter so there must be a wire from the dash clock rev counter and was wondering what colour this is.thanks
Andy335Touring
Solid Black wire on one of the two plugs i think
tomtomiS
if im right then the the plug u need is the one behind the rev counter, found out the other day that the plug on right ( blue??) does the electrics and bulbs for right hand side and the one on the left (white plug??) does the left. pardon me if im havin a blonde moment!!
eko
- Old timer
Can it not be wired into the C101 plug under the bonnet?
Ian332i or Brianmoore will be able to tell you for sure
BMW ECUs have an output to drive the rev counter. On an E30 it's a black wire which goes through pin 9 (IIRC), of the C101 connector.
No idea if the Ford signal is compatible, but there are others with cosworth engined E30s on the forum who should be able to tell you.
