M3 Owners with BBS RS.
f13ldy
Post Thu Nov 02, 2006 8:38 pm
What is the size and offset of your wheels and do you have any rubbing issues? Or did you have to roll your arches?
James.
tobias
Post Thu Nov 02, 2006 8:47 pm
good luck f13ldy. am sure you will get your answers im running mine bbs splits but not rs. no spacers needed but had to use spiggot rings 8)
f13ldy
Post Thu Nov 02, 2006 8:50 pm
Cheers Tobias...
Just out of interest what size and offset are they?
tobias
Post Thu Nov 02, 2006 8:56 pm
they are 17s and off the top of my head im not sure about offset. sets often come up on fleabay and there was a set of 18s on here not long ago. go by the name of bbs rc090 or bbs style 5 :D
harry_p
Post Fri Nov 03, 2006 12:05 am
hi, mine is on 16in BBS RS wheels. i think the fronts are 8in wide, but couldnt tell you the offset. i've never taken off the centre cap :o:
rears are 9in wide, et20 (pretty sure)
running 225 45 16 tyres both ends. no rubbing at all, ever. have been thinking of going up to 17s, and looks like theres plenty of room for a 235 40 17 on a 9in rear.
oh, car is lowered on eibach springs, but i dont know how much.
sorry thats all a bit vague, i've not had it that long :D
some pics in the gallery HERE
Jimb
Post Fri Nov 03, 2006 12:42 am
BBS RS061 - 8" 20mm offset and RS022 - 9" 24mm offset.
225/45 all fours - no rubbing, but the back looks tupid because the tire is stretched
225/45 front and 245/45 rear and the rear rubs when the bacxk seat is occupied...and the rear is up 1"
Cheers,
Jim
tobias
Post Fri Nov 03, 2006 1:25 pm
m3 cab looks great :D :P
f13ldy
Post Fri Nov 03, 2006 2:30 pm
Sweet.
The guy who I have as a contact is saying he can get me an ET40 Front and a ET27 rear.
Surely this causes me more problems than getting a full set of ET13.
I blaaady hate buying new wheels!!
harry_p
Post Fri Nov 03, 2006 5:04 pm
a high offset can be usefull, because it means you can play with spacers to get them sitting how you want them to.
start with a low offset and the wheels will stick out so far and there won't be anything you can do about it!
spacers are perfectly safe and accceptable as long as you use longer wheel bolts, and the wheels still locates on the centre of the hub, or the spacers are hubcentric.
tobias
Post Fri Nov 03, 2006 6:05 pm
f13ldy there is a set on here for sale that are coming off e30 m3 :D :D
c76jon
Post Fri Nov 03, 2006 6:08 pm
type 5 bbs if they are 8 fronts and 9 rears et20 and et22 respectively
if these are fitted with 215/40/17 and 245/35/17 these will not foul anywhere even on full lock
if car is on say billies and h and r springs again no fouling and no arch work needed
jon
tobias
Post Fri Nov 03, 2006 6:21 pm
hi jon
refurbing type 5s at the mo. do you have idea where i can get bolts??
