Where's the best place to get an exhaust for a 325i touring either part or full system , i know gsf and ecp sell them but does anyone else
thanks
325i exhaust
toby
http://www.motormec.co.uk/ genuine BMW OE marks supplied
also the zone shop sells some fancy ones
I bought a ecp one four years ago and it is already pretty shagged. Some people say that's good but I think I'd rather pay more and it to last a bit longer. The make I got was an Ernst.
http://www.c3bmw.co.uk/ also sell the genuine article but it's nowhere near you in Norwich
Do you have a 2 or 3 piece system?
david106
I think it's a 2 part the back box is quite long overall
cliffybabe
- Powered by Nelly
it sounds like a two piece if it was a 3 piece u'd only have a short pipe out the back of the box to the first connector
U could try posting a thread in the wanted section
toby
Yeah that sounds like a two part system. Are you looking to avoid ecp and gsf?
Motormec is only about 25 miles from Norwich and I would thin sell a much better product.
I don't think the front sections of the two part systems wear out too often so you will probably get away with just the rear box. You could tap in the last 7 digits of your chassis number into the parts catolgue at http://www.realoem.com/bmw/select.do to be sure to be sure... Get those bands that hold up the exhaust too - they are rubbish and rot away. I'm gonna paint mine with hamerite next time to slow down the rust - I've got a bent coat hanger holding it up at the moment.
david106
I've spotted one on ebay but it's off a 320i touring and it's in norwich but someone said the tail pipes are smaller on a 320i?
toby
I think a 320i is different - you'd have to check that.
If you're after a second hand one there should be one in the parts for sale section on the zone - and it wouldn't have to be from a touring - so long as it's a two piece exhaust
e30bmlover
- Ac Schnitzer prophet
another member from norwich!!! how u keeping? might have seen you about.david106 wrote:Where's the best place to get an exhaust for a 325i touring either part or full system , i know gsf and ecp sell them but does anyone else
thanks
david106
Hi e30bmlover,
I've only just bought my touring it's an e plate in lachs silver it need's a bit of work but I've bought it as a long-term project .
Everyone has been very helpful answering all my question's .
thanks
thanks
