Chitty Chity Bang Bang!!
Rosc0PColtrane
Post Thu Nov 02, 2006 9:31 am
Ctahcy title eh? Should be made into a film!!
Well, I have a little problem, think I may know the answer, but you very clever encyclopaedic oracle like bods may throw me a bone here.
The past few mornings, on my drive to work, as I accelerate up to Naitonal Sped limit, I change gear, into 4th or 5th, the car splutters, and if I keep my toe down, will back-fire, sending a plume of dusty smoke over any following vehicle.
I can avoid the back-fire by dipping the clutch and coaxing the revs back up and raising it again.
My understanding of back-fire is when unburned fuel is ignited in th ehot exhaust?
If so, what is causing this. It's not the best starter in the morning, inspite of recently being serviced. More so in the wet or cold weather. The Ht leads seemed to be ok. I'm thinking it's a poor spark and replacing the HT leads may be the answer.
However, what with the cooler weather, I'm thinking it also be, or compounded by, over fueling?
I had a E plate 520i before and that over fuelled, inspite of temp sensors being replaced.
Oh my car is a 320i Cab on a H plate. Any ideas would be gratefully received, oh mighty wise ones!!
winkeye
Steviec
Post Thu Nov 02, 2006 10:03 am
Have you checked the hose from the AFM to the inlet manifold for splits? Also, try removing the plug from the AFM and give it a clean up.
Dont know if it will help but its worth a try.
<a><IMG></a>
jmc330i
Post Thu Nov 02, 2006 10:30 am
IIRC a bad earth will cause a weak spark, you could try cleaning up the earth points - engine mount to chassis leg being the main one.
James
'91 325i Sport
'93 318i touring 16v
Rosc0PColtrane
Post Thu Nov 02, 2006 12:29 pm
cool, thanks!!
DRIFTBOY
Post Thu Nov 02, 2006 12:37 pm
I'd be surprised if H.T. leads were to blame.
As it's colder and damper now more likely moisture in the distributor cap.
Might be worth taking it off and having a look.
It could be one of dozens of things though, electrical, ignition or fuelling.
I recently fixed a friend's Escort for him which had similar symptoms.
I traced it to the exhaust rear box which had fallen apart inside!
Occasionally it back-fired and blew a load of wadding out and was ok again for a short time.
Rosc0PColtrane
Post Thu Nov 02, 2006 12:54 pm
DRIFTBOY wrote:I'd be surprised if H.T. leads were to blame.
Ok, thanks for that. Will check that at the weekend too
Martinaston
Post Thu Nov 02, 2006 1:18 pm
Check the colour of the spark plugs first, (damp/oily/brown/burnt) it should give you an idea if its a fuel or spark problem.
There is NO nucleus.
Rosc0PColtrane
Post Thu Nov 02, 2006 1:52 pm
cool. They were replaced less that 500 miles ago
DRIFTBOY
Post Thu Nov 02, 2006 6:41 pm
I bet you didn't know that "Chitty Chitty Bang Bang" actually has a rather rude meaning!
During one of the world wars soldiers were given, in certain circumstances, passes to go on leave for a day or two, theses were called 'chits'.
Then they would go to a big city and find 'ladies of the night' winkeye
to 'bang' !
Hence Chitty bang bang!
Why a fictional flying car was called that is a mystery!
What a bit of useless information.
No use to you fixing your car whatsoever! :roll:
Rosc0PColtrane
Post Fri Nov 03, 2006 8:31 am
DRIFTBOY wrote:I bet you didn't know that "Chitty Chitty Bang Bang" actually has a rather rude meaning!
to 'bang' !
Sweet, that's the kind of useless crap, that get's wedged inmy brain. Cool!!!! I bet there are some evil connotations in the film, or the author penned it very much tongue in cheek with that title!!! hahah He's had the joke on everyone!! winkeye :D
mark_i
Post Fri Nov 03, 2006 9:37 am
Yeah the author was Ian Fleming, who also wrote Jimmy Bond in his sparetime and owned an island in the Caribbean
--alpina--
Post Fri Nov 03, 2006 11:04 am
ALSO, i bet you didnt know the Chity Chity Bang Bang car itself was a FORD CAPRI chassis did you !!!
Jimi.
DRIFTBOY
Post Fri Nov 03, 2006 11:14 am
Wow! I didn't know that!
It's now stored in my 'useless facts and figures' department in my brain - which takes up about 95% of it's working capacity! 8O
--alpina--
Post Fri Nov 03, 2006 2:32 pm
that picture of the yellow lambourghini, whos the 2 people in the picture?
J
DRIFTBOY
Post Fri Nov 03, 2006 6:33 pm
That's my other car - and they are a couple of my bitches! :D
I wish!
That is the original 1971 prototype of the Lamborghini Countach (which was destroyed in crash testing and no longer exists) with a couple of - probably - Italian lovelies!
I'm a Lambo anorak! About time I changed that avatar pic though!
Sorry blatantarrogance, this isn't helping you fix your car, is it! :?
--alpina--
Post Fri Nov 03, 2006 7:51 pm
HAHAAAAAAAAAA like the bitches, oh and the car... well i noticed the girls, being it a 1971 picture.. i reckon those girls are a.k.a. grannies now with
Nice pic....
cheers...
Jimi
toughguych
Post Fri Dec 01, 2006 8:04 pm
Not grannies but definetly MILF's!!! winkeye
