Pics of Tourings with H&R cup kit
Gravy
Does anyone have any pics of any tourings with the H&R cup kit 60/40 drop? I think this would be a pretty good option to go for but am worried it may be too low for the touring?
I will be running standard 15" wheels either BBS or Ronal R10 Turbos!
Gravy
Just noticed there is a KW kit availabe with a 40/40 drop which may be better? Can anyone recommend or vouch for the KW kit (not coilovers)?
M5pilot
The Tourings look well nice with the Cup Kit and do not sit too low. It is a true 40mm lowering at the back.
The front being 60mm may be a little low if you have big speed humps everywhere.
The KW stuff is brilliant, I wish I'd had these on the Zone Shop earlier.
Really well setup suspension kit as is the H&R. They do a 40/40 kit.
Go for either because they are both brilliant.
Sal
Sal
Gravy
Cheers Sal, I'm basically putting togther my spec and therefore shopping list, coilovers would be plush but unecessary at this stage so was just trying to guage opinion for which way to go! I'm tempted to try the KW stuff to be fair, I'll be in touch........!
M5pilot
I tried the KW stuff - very nice.
You dont need coilovers if its a road car only.
Get some ARB's aswell because it will be serious fun then!
Sal
Sal
Gravy
Actually Sal, what sort of suspension mods can I do so as to keep the geometry correct to compensate for a drop in ride height, because obviously the camber, bump and rebound, castor etc etc will all change when the car is dropped because the wishbones will be at a different angle? Are there different bushes I can use etc?
Or am I speaking sh*te?!!!!
Hyperion
Hi Gravy
If i remember correctly a M5Pilot has a black touring running on 60/40 springs. i looked for a pic but couldnt find one, i remember seeing a pic in a tread somewhere, looked pretty mean,but the front 60 drop is low. I have a 40mm drop all around with a replica Alpina front spoiler and i still wack it everywhere
Not sure about and cant really vouch for the KW kit sorry.
EDIT:
sorry was being a dumbass and took long to reply to you didnt notice you were having a full on conversation with M5Pilot already
EDIT:
Gravy
Thats cool! cheers for your post - i think 40/40 would be adequate!
M5pilot
Bump and rebound are controlled by the dampers.Gravy wrote:Actually Sal, what sort of suspension mods can I do so as to keep the geometry correct to compensate for a drop in ride height, because obviously the camber, bump and rebound, castor etc etc will all change when the car is dropped because the wishbones will be at a different angle? Are there different bushes I can use etc?
Castor angle is not changed.
Rear negative camber with 40mm lowering is within tolerances according to the KDS alignment.
Fit powerflex eccentric control arm bushes to increase castor.
It all works very very well.
Sal
nonsense! alpina spoilers are fine on 60mm drops, u just have to be a bit careful i.e all the bloody time
Gravy
Awesome, thanks for all the info Sal, most helpful!
gareth
technically, it is. but not by a lot!M5pilot wrote:Castor angle is not changed.
gravy, if you find you need to adjust the rear camber, you can get offset bushes for the trailing arms
gcorky
- Boost Junkie
Morat
DAMN! that looks low at the front! No rubbing? What size wheels/tyres have you got on there?
Gravy
Thanks for the pic, I think 40/40 will suit me just fine!
M5pilot
They are fine really. I broke 2 cause I wasn't so careful.Simon13 wrote:nonsense! alpina spoilers are fine on 60mm drops, u just have to be a bit careful i.e all the bloody time
Sal
jamesc
..thats with 60/40 cab H&R Cup Kit.
James
Hyperion
i am still on my first one but it is in a very sorry state, not sure if i am gonna put another one one, but they do look very cool...decisions decisionsM5pilot wrote:They are fine really. I broke 2 cause I wasn't so careful.Simon13 wrote:nonsense! alpina spoilers are fine on 60mm drops, u just have to be a bit careful i.e all the bloody time
Sal
Gravy
Ah man, I'm get confused now! Or at least indecisive, that looks cool too!jamesc wrote:
James
gcorky
- Boost Junkie
Cotty
- Hartge Crew
This isnt H&R but KW struts and 60/40 springs plus some H&R ARB's
Havent had a problem with speed ramps or pillows. Wish the back was a bit lower. 60/60 would be really good
