The first thing i spotted was one of the sensor wires had rubbed through to the wire so i got this replaced but it wasn't the fault.
After searching the tech sections old posts on the subject it doesn't sound like a sensor or sensor wiring fault.
It's more pointing to the ABS ECU or one of the three(???) relays ?
All i've done tonight is to pull the two relays off on top of the pump to check for dirty/rusty connections, i've also checked the C101(?) plug on the bulk head as theres a trigger wire for the ABS runs through it but all the connections look clean.
In the fallowing post some one says theres a relay on top of the ECU above the glove box but i've taken the ECU off and i can't find it ? Is this a pre/post face lift change ?
Behind the glove box theres three relays, two Orange ones together and one Blue one. Is one of these for the ABS ?When i bought my 325 sport the light didnt work so i took out my clocks and found the bulb was missing , replaced the bulb only to find the light stayed on . In the end the fault was with a relay in the glovebox just above the silver control box
This is from the ETK, it looks like theres a relay above the ECU, i guess i need to have a look in the day light, god i hate these dark nights !
http://img406.imageshack.us/img406/8023/relays1vq5.jpg
I'm leaning towards a fried ECU or relay because like a pratt i vaguely remember shorting a spanner on one of the big Positive connections on the starter motor but i can't remember if the ABS fault started at the same time or not ?
I've read that jump starting can start these kind of problems off due to a spike or jolt of electricity i guess ?
Is there a built in fuse inside the ECU or relays ?
Not that i can get inside of the ECU any way because it's got funny shaped security screws
Oh, well MOT first thing tomorrow, i'm going to volenteer(sp?) to sit in the car and operate the lights/brakes/steering/ect for him to see if i can get away with it, even if i do i want fix it any way.
