Rear Brake Lines
k130
Mon Oct 30, 2006 8:44 pm
Hi
Last weekend I tried to fit a set of braided brake hoses, did OK but only got 4 of the 6 on as two of the four rear ones are well hidden under the rear crossmember.
Does anyone have any tips for doing this or do I need some sort of special tool??
Rob.
old_skool
Mon Oct 30, 2006 9:05 pm
No special tools, 11mm brake pipe spanner, a 14mm spanner for the hoses and patience. It isn't the easiest of jobs but it is possible. 8)
tobias
Tue Oct 31, 2006 12:43 am
as above done mine on sunday. may wanna removve heat sheild from above exhaust
LeeInMontreal
Tue Oct 31, 2006 1:07 am
The trick is that because you will not use the old rubber lines, you can cut them as close to the steel fittings as possible. That will allow you to use a deep socket and an extension. Use your ratchet wrench to undo it. Much easier. 10 minutes per side.
tobias
Tue Oct 31, 2006 1:09 am
wish i asked same q on sat
k130
Tue Oct 31, 2006 11:38 am
Thanks all for that.
I think I may have one more go at it then get my local garage to do it if I fail...
tobias
Tue Oct 31, 2006 5:23 pm
think positive alittle patience an you will be fine. goodluck :cool:
k130
Tue Oct 31, 2006 7:57 pm
cheers, will let you all know how it turns out...
