got lights on the cluster and check control lighting up.
gave it a go to see if I can get it started again before going any further. ( rear lights and headlights to go )
but just turns over. Does not seem to have any spark.
the loom swap is from a 325i 1989 car to a 325i 1986 cabby if that makes any diffrence, as i have a sneeking suspicion they might be????
so.... ECU or somthing needs to be changed ?? or engine looms were slightly diffrent on older cars,???? as i have a sneeking suspicion it might ??
for example in this photo I have these wires 'spare' ........ ( three wires went to it from the general direction of the instrument cluster and were
by the way the wires that went to this plug were green, yelow/white, and black
or am i missing somthing at the front end by the lights that needs to be wired up ????
Aled
