Hi, Does anyone know if the boot switch/light on the boot of a convertible should have more than 2 wires going to it. The only reason I ask is that my car is draining the battery at the moment and it looks like someone has done a bit of diy wiring on it. I know the power hood will only work if the boot is shut but I dont know if it use the light switch for this
Cheers Andrew
Boot light on convertible
Globulator
Usually the boot swith is not pushed down fully - press/glue a cap or something on it, so it gets pressed in more. Another 5mm is usually quite useful..
1986 325i 'vert, funk louder than standard.
"No Mr Bond, I expect you to tell me why your 4 litre, 282bhp sports car can't outrun some lardy old Mercs.."
Audio & electronic software: http://www.cutestudio.net
