how do you
ed325i
Post Sun Oct 29, 2006 8:19 pm
measure the et on a wheel ?
kam-325i
Post Sun Oct 29, 2006 8:30 pm
The datum is the face that mates to the hub......
Ok, imagine you have a cross section of a wheel, draw a line thru the cross section that goes top to bottom, with the face that mates to the wheel hub as the datum. the distance the mating bit is off the center line of the rim, thats the ET. i think its - for towards outside the rim.
http://www.mitsubishi-fto.org/parts/wheels/index.html
orangecurry
Post Sun Oct 29, 2006 8:33 pm
http://www.gomog.com/allmorgan/wheeloffset.html
but it should be stamped on the wheel
ed325i
Post Mon Oct 30, 2006 6:57 am
Thanks. what it is I have just gone to fit my mim 1900's and the fronts are hitting on the cailper :cry: I cant see where it tell you the et on them. I need to work out what spacers I am going to need.
Gouki
Post Mon Oct 30, 2006 11:41 am
chances are you'll need a spacer shim to clear the caliper about 3mm thick?
