i need an electrical expert
markyboy
Post Sun Oct 29, 2006 6:24 pm
i want to add a twin charging system, can some one do me a clear wireing diagram , thanks :mad:
kam-325i
Post Sun Oct 29, 2006 6:27 pm
For Charging both battries at once or switching ?
zaust
Zone day release
What are you planning to run..?
M30 Tech 1 Touring on gas.
markyboy
Post Sun Oct 29, 2006 6:31 pm
want to charge both at same time, am planning to use the 2nd battery for another amp i have but its a big one so its drawing to much for one battery as i have another 2 amps running of the standard battery. i have the relay and power leads , just need to know where to put them. :cry: 8O
kam-325i
Post Sun Oct 29, 2006 6:34 pm
Might need to get a bigger alternator. Do you want the charging to be automatic.
Might be easier to get a bigger battery........i got a huge one for a diesel engine, one benifit is that its spins the starter a lot quicker in the mornings !!!
markyboy
Post Sun Oct 29, 2006 6:36 pm
yer could do ,
markyboy
Post Sun Oct 29, 2006 6:43 pm
but will that give enough power 2 run 2 amps without dimming the lights and crap
kam-325i
Post Sun Oct 29, 2006 6:48 pm
Depends on how big the amps are.........
What engine have you got.......
Normally, the best option is to get a bigger alternator and bigger battery....
zaust
Zone day release
Post Sun Oct 29, 2006 6:51 pm
I use the standered alt and a normal battery, have two massive amp's and never have a problem unless i leave it runing for an hour with the engine off..
How ever if you reall still want another battery, You can go to a caravan place and buy a a charging relay.
Consist of earth wire, Constant live, Switch Live 1 fuse and a live to your extra battery ,Which will need it's own earth. should be more than you need fella.
:D :D
Andy325i
Post Sun Oct 29, 2006 6:58 pm
markyboy wrote:but will that give enough power 2 run 2 amps without dimming the lights and crap
I am guessing you are running a power cap?
Andy
