just read the zone article on the OBC retrofit.
couple of questions :
when installed, the OBC wiring loom/harness (july 1990) has two connectors on the right hand side
1/ white 2-pin with a blue and brown wires
2/ green 4-pin with green, green/red, brown, brown/yellow wires
what position do they plug into...somewhere in the white junction box behind the glove box?
Also, the previous owner has cut two of the wires from the yellow speedo connector.
the brown is an earth, but what about the red/black?
OBC wiring loom
E30Mark
The junction box behind the glove-box has different size / shape connector ports, the mating connectors will only fit in one position...
The white 2-pin with a blue and brown wires is for the outside air tamp sender
The green 4-pin with green, green/red, brown, brown/yellow wires are mainly connected with the horn module, which personally i would not bother to fit. The BMW code immobiliser is totally useless... I think this is the plug you just leave unattached. Otherwise you will not be able to switch of the engine once started!
Can you get some pictures? the tech write up needs some!!!
Good luck
Good luck
PM for details
PM for details
E30Mark
P.s. I think the cut black / red is probably horn related, so you can just ignore that one too!
In fact if your not fitting the horn, don't bother fitting the relay module that sits above the ECU. The OBC will get all the power / signals it needs from the back of the cluster.
PM for details
PM for details
nickso
- Location: Go do that voodoo that you do so welllllllll!!
the white two pin with blue and brown goes to the outside temp sensor.
cant remember the rest and i dont have a wiring diagram handy
'88 e30 328i M52 track bint.
nickso
oops too slow
Only OBC wiring that is needed are the loom from yellow cluster plug to OBC, the single wire to the column stalk switch, and the wire down to the external temp sensor.
Everything else is for the useless immobiliser and its alarm.
mark_i
Thanks all, the one function I do want is the is the gong which is connected to the useless, unloved unwanted black relay box.
E30Mark, I'll forward you the pictures once I figure out the camera settings.
Sorry, yes, forgot about the gong. Comes off the loom to the black box, but has nothing to do with it.
mark_i
Cheers Brian, bong! its getting cold tonite, bong! another 3 points, bong!
dannosail
A bit late in the post but this might help:Can you get some pictures? the tech write up needs some!!!
This is engine bay loom. Black and blue connectors connect Temp Sensor and Gong respectively.
The other bundle, far left connects to the junction box behind the glove box, brown is earth (
