Oil Light
Keg_gt
oil light stays on at idle but goes away when revs increase what is the problem aaa its a m20 2.5 e30 can any one help ? some one sujested oil pump?
If you're lucky, oil pressure switch is knackered, if you're not, engine is knackered.
Simon325i
Have the same problem on mine recently but if you look in the handbook it says this is normal
Car has just been serviced and it did'nt come on when they had it - only comes on once car is warmed up.
orangecurry
when a car engine is 'warm', the oil is 'warm', and so is a lot thinner - therefore oil pressure drops; if there is a 'problem' somewhere, the oil pressure drops too low, and the light comes on.
as Brian says, it is likely that 'either the oil pressure switch is knackered, or engine is knackered.'
where does it say that in the manual? which page?
Keg_gt
Doesnt sound normal to me if the oil pressure is low then the oil isnt getting around properly. i went to my local Engine Shop and they said most likely the oil pump is on its way out so getting it changed Ԛ£49 for pump form German Swedish and French. i will give it a service at the same time. they also said possibly the mains bearings but that is unlikly as it would knock like a Tw@t. and it doesnt runs fine and sounds fine.
rmt
Oil pressure switches tend to fail on old cars, I have had a simaler problem on most of my cars and it has always been the switch not the engine at fault. New switches cost very little and are easy to fit. It is always worth replacing the switch.
Keg_gt
ok well im installing a pressure gauge having the oil pump changed and seeing what happens really
Keg_gt
Just cleaned sender cable as was full of oil on the conection and put it back on ad hey presto no more oil light so ive either broke it real bad or its fixed
Oil leaking through the switch is common, and will mess up the pressure at which it works.
Recommend you change the switch.
Lot cheaper than an unnecessary oil pump. (I've never seen a duff one).
Globulator
If it doesn't go away with a new sensor:
Also can be caused by a blocked filter - as excess pressure is 'lost' in the filter opening the bypass valve.
However usually filters only get blocked by oil additives (otherwise known as engine destroyers).
Non-synthetic oil gets thinner as it gets older - so may also happen if your oil viscosity has returned to base (10sae for 10w40).
1986 325i 'vert, funk louder than standard.
"No Mr Bond, I expect you to tell me why your 4 litre, 282bhp sports car can't outrun some lardy old Mercs.."
Audio & electronic software: http://www.cutestudio.net
Simon325i
Orangecurry - its on page 23!
orangecurry
right - that's page 23 gone from my manual then! Hope there's nothing useful on the back of that page
dobbie82
- Location: Dolgellau, Wales (NOT A TRADER,broken a car,got lots of bits)
I have had this problem a few times..
on my rover 214 the oil pump was knackered, on the 320i touring there was a break in the oil pressure switch wire, so when it was at idle (a bit lumpy) the oil light flickered on.
simplest to fix was my toyota last week, oil pressure light came on at idle, reason being? no damn oil in it! why do dealers always seem to sell cars with no oil? (well not no oil but took nearly a litre to get it back to half way between min and max)
e30 related ebay auctions + shop(MY Stuff for Sale), http://tinyurl.com/64aufr
My Feedback on the e30zone: http://tinyurl.com/dobbie82feedback
