Engine change
Guest
Post Mon Jan 17, 2005 1:38 pm
hi want to do an engine swap in my 320i ,i want to drop a 325i lump in ,but not to sure whats involved and if i need to change any of the running gear on the main brain ,any info would be appreciated :)
E30Adam
Post Mon Jan 17, 2005 2:59 pm
To do it properly you'll need the engine, gearbox and diff although the gearbox and diff aren't essential for running, the gearing will be wrong.
You'll also need either a chip from a 325i ECU or the actual ECU from a 325. I'd also upgrade the rear brakes to discs.
2.8 Litre M20 powered - Essen Sie meinen Staub biatch
325i-sport
Post Mon Jan 17, 2005 3:19 pm
i have everything you need except for the engine if your interested. ecu brakes, shocks, box, diff
karlp
Post Mon Jan 17, 2005 3:51 pm
I have everything including engine and ancillaries.
Karl
