how many do you want dude!!!!
if you were to break it, hang onto the rad and flywheel / clutch. i know you're getting the lump right back but more space is never a bad thing and a thinner rad may even allow you to get the dizzy cap off without draining the coolant!
the E28 has a lighter single mass flywheel. this is what i'm running. i've not seen a E32/34 one as my donor was an auto but i have pics of a E28 one if you wanna compare?
the engine is higher compression so will be a bit quicker but afaik isn't so simple to drop in as the later one. the wiring isn't as close and there is a water elbow on the rear of the head that makes space a lot tighter. (the E32/4 one is on the side of the head.) also , the exhaust manifold point towards the bulkhead, though the E32/4 one may fit?
the dogleg box is cool but i've heard they're not as tough. plus you know you'll look a tit grinding reverse at least once!
oh, i think i remember something about the engine mounts being different too... (on e30.de)
the prop would be useful as a donor for a hybrid.
have a look on E30.de as there is a lot of info regarding both donor types.
