E38 to E34?
Rich25i
Post Mon Oct 23, 2006 7:43 pm
Hi can anyone on here tell me if E38 7 series wheels will fit a E34?
Thanks in advance
Rich
stuartgallafant
Post Mon Oct 23, 2006 8:38 pm
possibly? most probably not, but possibly...
d6dph
Post Mon Oct 23, 2006 8:41 pm
stuartgallafant wrote:possibly? most probably not, but possibly...
Congratulations on the most vauge reply ever! :lol:
stuartgallafant
Post Mon Oct 23, 2006 8:59 pm
thanks dave....
Rich25i
Post Mon Oct 23, 2006 9:22 pm
Thanks for the vauge reply...
:mad:
stuartgallafant
Post Mon Oct 23, 2006 9:55 pm
well i know the E39 wheels fit on the E38, but i think the hub has a smaller spigot on the E34...
is that better? i dont own a bloody boat, so im not up-to-date on their specs...
Ant
Retired Team Member
Retired Team Member
Post Mon Oct 23, 2006 10:01 pm
some late e34 M5's have the M parallells fitted as std, PCD is the same, offset may be an issue though....
can you not try one to fit locally, then comitt funds ?
Rich25i
Post Mon Oct 23, 2006 10:04 pm
Thanks ant for a non vague reply! :D
I can try the wheels on tomorrow now so will have a go. was just trying to see if it would be worth the bother. i have odd wheels at the mo 8O
Thanks again
Rich
E30cabrioman
Post Tue Oct 24, 2006 12:58 am
E38 wheels will fit straight on the E34. may need a small spacer on front depending on suspension and tyre choice. ,similer to some 325 E30's with rubbing on strut issues.
E38 has same centre bore as E34 72.5mm ,ET 20mm
while the E39 has a 74mm centre bore requiring spigot rings :D
Wheel/tire combination
15x7" Wheels (OEM)
205/65-15
225/60-15
16x7.5" Wheels:
215/55-16
225/55-16
17x7 - 7.5 - 8 - 8.5" Wheels:
235/45-17
255/40-17
18x8.5" Wheels:
235/40-18
245/40-18
265/35-18
19x9" Wheels:
245/35-19
275/30-19
Hope this helps winkeye
325i Cab
E39 V8
Rich25i
Post Tue Oct 24, 2006 10:29 am
Thank you very much this helps loads.
I think there 18 inch 740 wheels multispoke design will be going on car with standard suspension so will check the fronts closely
Thanks again
RICH
