My number Six Exhaust ROcker has Cracked due to TImimg Belt!!! :cry:
Can one Replace the Rocker without removing the head.
Maybe lower the motor and removing the shaft and just sliding on a new
Rocker....... Or not so easy????
Thank you :cool:
Rocker Replacment
gazza
what do you mean due to timing belt ....ive seen the rocker break as a result of the timing belt snapping which means the pistons have hit the valves which in turn have damaged the rocker if it has snapped you are not going to get away with replacing a rocker i would want the head off to see what else is damaged(bent valves damaged pistons) if the timing belt has slipped of the pulley then you could still have serious damage to your engine ....either way i would take the head off
if not there is a tech article on this site that will show you how to strip the head
good luck and lets hope its something else and does only need a rocker
