any ideas? could i have missed somthing when i installed it or could there be a dodge connection some were ? were abouts??
obc don't work on m/g
appletree
my obc has never workeng on the m/g function since i installed it on my IS and ui thought this was just because it had a 6 pot coding plug in it so i ordered the on e for the Is from germany and it still doesnt work.
Steviec
Does the MPG info get read from the back of the dial cluster (small green connector)? If so, might be worth checking its in the right place?
<a><IMG></a>
appletree
do you mean the speedo cluster or the back of the Obc? i havent got any wire plugged in the speedo cluster?? sure i followed the zone guide when i put the OBC in
gcorky
- Boost Junkie
Cloggy Saint
orangecurry
there is a large yellow plug on the OBC loom which goes in the back of the cluster into a large yellow socket, but that is the main input to the OBC; you'll definately be needing that
The m/g function on the OBC uses the same info from the cluster that works the economy gauge under the tacho, som if this works, it's probably a problem with the OBC.
All the data for the OBC, except external temperature, comes along the single loom from the yellow socket on the cluster.
appletree
right, the big yellow plug is in and the every thing works on both the OBC and the Speedo cluster expt the M/G on the obc.
orangecurry
I found that the OBC can be temperamental - try disconnecting then reconnecting it to the loom with the ignition on
is that OK Brian? It didn't do mine any harm...
disclaimer - doing anything that I suggest may or may not result in a total catastrophe
Unlikely to do any harm, but easier to disconnect the battery for a couple of minutes if the cluster is screwed in place.orangecurry wrote:I found that the OBC can be temperamental - try disconnecting then reconnecting it to the loom with the ignition on
orangecurry
no no no - you have to do it with the ignition on..... I suppose you could do it your way (with the ignition on)... I suppose
but then the 'petrol fuelling stalling at junctions' might happen - swings and roundabouts
just pull the rear of the OBC off then put it back on with the ignition on; it only needs the dash to be in pieces
I mean with the ignition on. Couple of minutes with the battery disconnected doesn't upset the idle settings in my experience, but make sure you have the keys or a window open, as reconnecting a battery usually arms the alarm and engages the central locking.
