I foolishly left my key in the door lock the other night, turned in the lock position. Since then the central locking no longer works. Any ideas what the problem could be?
It's an E30 M3.
Central locking fault
tonydavis
E30Mark
http://www.e30zone.net/modules.php?name ... ocking.htm
Have a read through the above link, should shed some light on the system. You may have overheated the relay, so you might have to re-solder the bit back together as shown in the article above.
Welcome! nice to see another 'local' here
PM for details
PM for details
E30Mark
Your not the Tony Davis form Bowman yachts are you? seeing your interests.....
PM for details
PM for details
tonydavis
No, not guilty... I work in Poole, live in Alderholt.E30Mark wrote:Your not the Tony Davis form Bowman yachts are you? seeing your interests.....
Thanks for the info, I'll give it a try.
E30Mark
Hi Tony,
Hope you fix it OK, I used to work for Tony Davis @ Bowman Power, but he also used to own Bowman Yachts in Southampton! and i know he lives in the Dorset / Hants border area...
If you fancy a meet, there is one on 5th Novemeber!
http://www.e30zone.net/modules.php?name ... c&p=498037
PM for details
PM for details
