Hey people, am i correct in assuming that the VIN on my E30 is near the middle of the scuttle panel just outside the bonet seal, only visible when the bonet is open?
Also, has anyone ever tried sticking the last 7 digits of that 8 digit number into the search box on www.realOem.com? If so how did it go?
Vin number and www.realOem.com
Templ8e30
It's not that number mate, the number you need is on the same panel but closer to the battery (and on the VIN plate above the drivers side headlights under the bonnet) and is 17 digits long.
Usually starts with WBAAA.
Cheers,
Iain T
Cheers,
Iain T
2007 Mazda 6 2.0 estate
thebigone
on your v5 also
Chris
Aha, cheers found it. all sorted now
Thanks for the help.
